Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 9th February 2012, 12:54 AM   #1951
ro9397 is offline ro9397  United States
My main amp is line-level high-pass crossed, 1st order @ 275 Hz, 3rd order @ 80 Hz, requiring no deep bass.
Any reason not to install three Ncore amps in one chassis (pure analog Trinaural 3.1 music system)? The center is the most critical channel (think of the L/R as ambiance effects). A mono bloc has no proximity advantage because the equipment rack is 12" behind the center speaker.
Which, if any, Hypex power supply is recommended for three Ncore amps?
If anyone plans or desires to cut/fit a specific chassis for three Ncore amps, please PM me. It might be less costly to prepare two chassis simultaneously.
Sum total work appears to be:
  1. Purchase appropriate chassis, 3x Ncore amps, Hypex power supply, transformer, inputs/outputs, and fasteners
  2. Cut/punch chassis holes
  3. Install and wire all parts
Am I missing something?
Pros/cons EI core vs. toroidal transformer?
Is there easy method to add high-pass line-level crossover to Ncore? Prefer 4th order, fixed 120 Hz OK.
James
"Television is the poor man's whiskey." Russel Baker
Old 9th February 2012, 02:10 AM   #1952
Originally Posted by ro9397 View Post
Thank you for that promise. Very much looking forward to reading your feedback. ETA? If not this thread, where?
Your comment reminds of the one of Zaph Audio's better DIY monitor designs...searched forever and could hardly find a couple sentences of feedback.
My nCores are scheduled to arrive tomorrow morning. I will post my review right here and perhaps on another forum.
Old 9th February 2012, 03:29 AM   #1953
Originally Posted by Jan-Peter View Post
Yep...that's correct...
Jan-Peter
These days
High-end = High Price tag - Fancy box - and the least amount spent on the electronics that they can get away with
Old 9th February 2012, 07:25 AM   #1954
john dozier's Avatar
+10
Evil looms. Cowboy up. Kill it. Get Paid.
Old 9th February 2012, 07:49 AM   #1955
Send a message via Yahoo to mr_push_pull
before getting the Confidence's I had planned to build Zaph's ZD5 but what made me not to was this lack of reports.
OTOH look at my report in the multi-way section, after my friend built the Seas Idunn project. I was as frank as I could be (my only involvement was building the XO's) and I compared them with a commercial system in the same price range. but TBH I wish I kept my mouth shut. but if it were about this we'd see some NCORE's for sale already (I wish...)
Originally Posted by Trevor White View Post
These days
what is really really funny about these types is that they can't get right even the most basic stuff even the die hard subjectivist can't argue about, like SNR and channel separation. my favorites are 47labs and Audio Note. I'm always delighted to read about the "5 mm signal path" and then look at the channel separation graph boasting an impressive 40dB
one local company is doing some OEM stuff for the likes of MSB Tech and PS Audio and knowing the owner I have some insights on this. some "high end" makers are basically case designers with a marketing department, all actual electronic design being outsourced. and to avoid any useless discussion, I'll add the disclaimer that I'm not talking the two names that I mentioned above, reportedly they actually do have strong engineering departments.
so is there a chance that we actually read a third report tomorrow?
we all love a good ol' stereotype until it's against us
Old 9th February 2012, 08:11 AM   #1956
That's the cynical view. The non-cynical view of most high end is having philosophies instead of facts and esoteric parts instead of circuitry. Oh no that's still cynical. But there's a point. If one cared to look inside most high end equipment you'd find that whatever they lacked in knowledge they sure made up in expensive content. Heck, some buy up loads of obsolete parts under the presumption that they're better than the new stuff and on the other end of the scale some have their own power transistors made in an esoteric new technology. These guys are spending money, not raking it in.
Leaving aside the question of how well-designed the innards of an audio products are, there are some very basic economic facts:
1) Regardless of market, the mark-up between the BOM and the end-user price is around a factor 5. Most of that goes to the retailer. Then the distributor. The remaining pittance goes to the manufacturer.
2) Economy of scale: production cost drops with the logarithm of quantity until you hit the raw materials cost (i'm told that the old Philips TV factory in Bruges could reliably estimate the cost of a TV set by weighing it). The same product, manufactured in tens or in thousands ends up with a markedly different price tag.
3) People want their money's worth. You spend 5k on a piece of kit, it has to look expensive. I'm talking fit and finish, not looks. It may look "butt ugly" so long as it's polished like a baby's bottom (with only as many visible seams).
So you want to make a "better than average" product? That will make it more expensive than average. So you'll sell fewer of them. So your manufacturing cost will go up and you need to increase your profit margin. The price starts getting a bit "exclusive". So people will not want the same folded casework as a $25 DVD player. Some of these look pretty sleek with the sort of plastic casting that's available when you make 100k units. If you want to get the same quality with 1k units, it'll have to be machined. This spiral continues until a company almost but not entirely runs out of customers and equilibrium is reached. Of course, that leaves room for many more small companies with slightly different offerings who appeal to a different but equally small subset of potential audio buyers. All it takes is the above 3 obvious truths to explain why the high end market is saturated with innumerous tiny companies trying to be slightly different from one another. The same spiral explains why the middle segment (where say 1500 euros would buy a very decent stereo) has pretty much vanished from the market.
People seem to have the impression that manufacturers of high end gear are greedy bastards who are making way too much money. I can assure you that the companies that churn out cheapo DVD players have a boardroom full of way richer guys, none of whom actually give a damn for audio. Even a middle manager may fetch rather more than some of the people manufacturing the high-end gear that's meeting with such opprobium for their price tag.
You can have me ranting about the complete lack of technical sense shown by equipment designers and whatnot, but as far as economics goes, the smart ones and the stupid ones are in the same boat.
There's a time for everything, and this is not it.
Old 9th February 2012, 08:47 AM   #1957
Bruno, that's exactly my view and I can't say I disagree with anything at all.
what I do find sad is that I know the run of the mill, not technically inclined audiophile's view too. and all too ofter there is this this blind, unconditional, religious trust in anything with an impressive case and a name that would rather suggest expensive wine.
Old 9th February 2012, 11:06 AM   #1958
MSB Tech ?? Is that the same company that bags the ESS SABRE DAC claiming that it is only a 6 bit DAC even though the measurements say otherwise ??
What about 32 bit DACs
So the hot new 32 bit DAC is actually a 6 bit DAC! Right from their own white paper. It is undoubtably a good DAC for the mass consumer market it was designed for. It is certainly nothing of interest to the high-end community, especially as the the DAC, digital filter and sample rate converter that cannot be dissabled are all bundled in a single chip so no opportunity exists to improve its performance.
So be informed and do not be fooled by the over-the-top advertising made by the audio companies who actually use this $39 chip
And of course it is only fit for the consumer market Sounds like a dude that is worried about a mass market high performance dac that essentially makes his megabuck all singing all dancing DAC obsolete
Old 9th February 2012, 11:33 AM   #1959
yes it's the same MSB Tech.
indeed that, what should I call it, rant? seems to be written by the marketing dept in collaboration with the janitor. I don't know much about their products but claiming that the ESS chip is actually 6 bit doesn't sound like coming from an engineer. they should've stopped after saying that the digital filter and async resampler can't be bypassed.
Old 9th February 2012, 11:34 AM   #1960
acousticimagery's Avatar
With you all the way Bruno.
I make no secret of the fact that my little company, ACOUSTICIMAGERY acousticimagery - HOME uses standard Hypex UcD400HG+HxR modules and the SMPS400A400 in our D400M mono amps and we do so for two main reasons.
1. I cannot design electronics but, I've listened to plenty of amps over the last 30 years to know how a good design should sound.
2. The Hypex Class D is the best amp I can buy which is right for me and the plans I have for the future development of my company.
Bruno is dead right about the margins and if you want to stand out then you have to go the 'extra mile' to get the detail right and it doesn't come cheap.
One thing never mentioned in all the discussions about small manufacturers is EMC and CE approval testing. Each product you offer for sale has to be tested by an independent laboratory and my own costs for our pre-amp and the D400M power amps is approx 6000 euros each to be certified by TUV.
Our confidence in Bruno, Jan-Peter and Hypex was recently justified beyond even my wildest dreams when Hi Fi News( Jan 2012 issue ) reviewed our amps and heaped (justifiable) praise on the Hypex modules.
The DIY community is very privileged to have access to true audiophile components such as the Hypex modules and with NCore even more so.
Meanwhile the vast majority of the 'music listening public' are happy with an I Pod and of the 5% or so who are audiophiles, the vast majority of them wouldn't ever dream of grasping a soldering iron and 'doing it themselves' so hopefully there's room for us small manufacturers to provide excellent hi fi equipment, with the help of suppliers like Hypex.
Cheers........John
Hypex problem, who can help Hansms Class D 8 10th March 2011 08:18 PM
Hypex steveww Class D 14 18th November 2010 01:44 PM
Question for those who have tried hypex smps with hypex modules avian Class D 12 3rd March 2009 09:30 AM
Hypex UcD 180AD + signal wires, Power Supply ST, Hypex Transformer TR100A c10h12n2 Swap Meet 7 7th July 2007 03:55 PM
FS: Hypex UcD 400/180AD, hypex toroid Archmage Swap Meet 4 14th November 2006 04:23 AM
Copyright ©1999-2013 diyAudio
