hypex ncore - Page 105 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 28th December 2011, 10:11 PM   #1041
tiki is offline tiki  Germany
tiki's Avatar
Originally Posted by Bruno Putzeys View Post
...(strong preference for the "chemtronics soder wick" brand, the rest is rubbish)
Thanks, I "used" the second types until now.
and finally remove the flux with a tissue and acetone.
Alcohol or spirit should do that as well, a bit less harmful.
tiki
Old 28th December 2011, 10:16 PM   #1042
Send a message via Yahoo to mr_push_pull
just curious... how come no epoxy-covered "secret circuit" like found on UCD's?
we all love a good ol' stereotype until it's against us
Old 28th December 2011, 10:28 PM   #1043
Hard to cover in epoxy what you've published in patents and papers.
There's a time for everything, and this is not it.
Old 28th December 2011, 11:53 PM   #1044
Originally Posted by StigErik View Post
1) I have, its fairly easy using a solder pump.
In the same time it takes to remove and clear the holes for one through-hole resistor, you can remove 5-10 SMD ones.
Just use a pair of precision tweezers to hold the part and heat both pads (if you move fast enough you can heat the other side before the 1st one solidifies).
Old 29th December 2011, 02:23 AM   #1045
Tom4s is offline Tom4s  Luxembourg
Off topic: I'm being hounded here to place the 1000th post on this thread. Not bad. Some threads about new projects reach 3000 and still no hardware in sight
Being the OP, and having been diverted to lots of other stuff this fall, I finally had some time to catch up on this thread -- and got totally blown away by how well the project has been received. The price for the module is just at the right spot too. Congratulations to the whole Hypex team!! 2012 is sure to be a fine year for you, and I'm pleased to see that you have stayed well clear of any Osborne effect.
So, should I order two power supplies or is one enough for a pair of these puppies? I have a pair of ancient (but well kept and lovingly maintained) Infinity Quantum 3 speakers, 4 Ohms nominally but will probably go down below 3 at some frequencies, and they're very inefficient. I like to play loud at times, so I guess two PS's should be on the order.
Oh, and what is the input sensitivity (Volts, please) for maximum rated output with and without R141 in place?
Old 29th December 2011, 07:09 AM   #1046
A mention was made a while back to Ncore technology being incorporated into the UcD250 and a new UcD400oem.
Are the the UcD400oem's shipping now the "new" units with the upgrades, or is that amp still to come?
Old 29th December 2011, 07:13 AM   #1047
@tom4s, I suppose that means you did a good thing starting the thread
One supply will go up to 2x300W. Personally I'd think this is enough in most circumstances but with two 4-ohm speakers you can definitely force the supply into shutdown.
Since gain is (very nearly) 20x, you need 2Vrms for full power. When you drop the input stage gain to 1 you need 9.6V. In that case please drive the input with a symmetrical voltage source because 9.6V on only one input terminal will overdrive it before the amp clips. Unless you're a fan of very efficient loudspeakers I'd say leave R141 in place.
@lotus, the current UcD400oems are indeed the updated version.
Old 29th December 2011, 07:34 AM   #1048
Great to know!
Thank you much for the reply.
Old 29th December 2011, 07:51 AM   #1049
StigErik's Avatar
I've connected my DAC directly to the NC400's, with the volume control in the digital domain. It delivers 12 dBu, which is 3.09 V. With R141 removed, I get 12.4 dB gain, which is 4.17x. At 0 DBFS from the DAC, that gives me 3.09 x 4.17 = 12.8853 V, which is 20,75W into 8 ohms. Not all that much, but it is actually more than I ever need. I now that, because I never ever reach 0 DBFS from the DAC....
Which also means that I am operating in the range of the NC400 where distortion is almost unmeasureable.
dipoles dipoles dipoles dipoles dipoles dipoles dipoles dipoles and dipoles
Old 29th December 2011, 09:54 AM   #1050
@Bruno, it is an honour to have started this thread! Thanks for the suggestions. But is there anything to gain with a dual mono configuration, other than maximum power?
with the volume control in the digital domain. [...] I never ever reach 0 DBFS
@StigErik, you do know that this means that you never ever use the full bit resolution of your DAC? In fact, at low listening levels you would introduce lo-fi "bit crunching" distortion. I now see why you wanted to decrease the Ncore input sensitivity... In your situation I think I would set the DAC at full scale output and use a passive volume control, such as this little unit. or perhaps this one. (Amazing prices for balanced volume controls.)
Hypex problem, who can help Hansms Class D 9 18th August 2013 07:49 AM
Hypex steveww Class D 14 18th November 2010 02:44 PM
Question for those who have tried hypex smps with hypex modules avian Class D 12 3rd March 2009 10:30 AM
Hypex UcD 180AD + signal wires, Power Supply ST, Hypex Transformer TR100A c10h12n2 Swap Meet 7 7th July 2007 04:55 PM
FS: Hypex UcD 400/180AD, hypex toroid Archmage Swap Meet 4 14th November 2006 05:23 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
