KT88 SE Basic or Master Kit - Page 16 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 16th November 2012, 01:45 AM   #151
I've have a few (maybe 3 or 4) chassis left that are powder coated RAL9006. I'll sell for the same price until they are gone. The attached photos show what it will look like when built. You will have to refinish the transformer laminations as they can be somewhat rough. To achieve the mirror finish on the caps use automotive chrome/aluminum polish.
Old 17th November 2012, 01:45 PM   #152
regiregi22's Avatar
I have been using this kit for 6 months and all I got to say is that I recommend it alot, top quality components used everywhere and a clean layout. Sound is... just awesome!
diyAudio, doing it as big as you can, JUST BECAUSE WE CAN!
Old 24th November 2012, 04:14 AM   #153
freax's Avatar
How much for shipping will a master kit cost for Australia?
Where can I shoot off an email so I can give you my personal details and get a quote on the master kit.
Does the chassis come in a black finish at all from you? I would be interested in a black powdercoat finish too, and would even prefer it over the classic looking gray.
If it doesnt then I will just purchase the grey powdercoat finish and paint over the top plate with my own colour.
Do the wood panels come in any walnut finish? if not then leave it bare and I will do it myself.
diyaudio is against your rights. I do not have the right to be forgotten and after asking the issue has been ignored, therefore I'm leaving (peacefully) for this reason. I stand up for my rights. So long and thanks for all the Fish
Old 24th November 2012, 12:56 PM   #154
I sent you a PM with the shipping details.
I don't have the chassis in black, but since you are going to recoat, I would send a raw aluminum chassis instead of powder coated.
The wood end panels supplied are solid walnut. They have a light smooth finish. They look good.
Old 24th November 2012, 01:32 PM   #155
freax's Avatar
Yes I got that, thank you very much.
I will be getting it in a raw aluminium chassis.
I will fill you in with further information via email when funds are available and will request a paypal invoice upon that day.
Old 26th November 2012, 06:48 PM   #156
freax's Avatar
Paid
Old 27th November 2012, 07:18 AM   #157
freax's Avatar
Originally Posted by regiregi22 View Post
Hello folks!
As I previously said, my plan was to mount the cover cage on this enclosure. The manufacturer advises that it is not compatible with the wood side panels, but after some careful planning I devised a way to achieve it. Suming it up, you have to mount upside-downthe wood side panels, then you break (or cut) a bit of the prominent wood that otherwise wouldn't allow you to screw down the bottom cover.
To allow to switch between Triode and Ultralineal mode, I have drilled a hole that allows you to switch if aided by a pencil or whatever stick-shaped object you may have around.
where is this cover from? I would also like to purchase one, simply for peace of mind when transporting my amplifier.
Old 27th November 2012, 05:24 PM   #158
This is the cover that Regi is talking about, 1451-30:
Hammond Mfg. - Perforated Chassis Covers (1451 Series)
It will not work if using the walnut side panels, as you can see, without some major modification.
Old 8th December 2012, 01:47 PM   #159
regiregi22's Avatar
Hey, get that, I got some small aluminium plates lasser written to show both UL and Triode connections.
Regarding how to install the mesh cover, it's a matter of compromises. You have to choose between easily installing ONLY the mesh cover, easily installing the wood panels, or installing both of them involving a bit of trouble as I did.
First, you take the wood panels and turn them upside down. That way you put upside the carved side of it, what will allow you to place the mesh at the same time that the panels. Then, you have to cut the wood in order to allow the bottom plate to be installed. You can not do it, but it may pose a safety problem. You make some extra holes to properly screw and nut the mesh. I made a hollow hole on the wood panel to allocate the screw's head.
Have a look at the mesh and enclosure pictures from Hammond's website and you will visually realize what I have explanied that bad (I'm sorry!).
Please do not hesitate asking any doubt,
Best regards!
Old 8th December 2012, 01:51 PM   #160
regiregi22's Avatar
And, yes, it has a total of 6x screws per side supporting everything. Two for each handle, two on each side of the mesh and two dedicated for each wood panel. Feels quite sturdy when lifthing the ~16 Kg. :-)
KT88 SE Complete Kit scott17 Tubes / Valves 289 4th March 2013 08:09 PM
AnalogMetric 6L6GC SE amp kit...thoughts about this kit? jmillerdoc Tubes / Valves 2 16th November 2009 02:51 PM
Kt88 Se overdrajv Tubes / Valves 0 16th December 2008 12:26 PM
My KT88 SE project JesseG Tubes / Valves 8 20th April 2008 04:26 AM
Kt88 Se hacknet Tubes / Valves 9 10th September 2004 08:19 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
