| Vendor's Bazaar Commercial Vendors large & small hawking their wares |
If you are interested in switch-mode power supplies for audio amplifiers, you may want to check this link:
http://www.poweramp.ro/forum/viewtopic.php?f=14&t=2 This is an open project intended to be used for Audio Power Amplifiers, Class AB or Class D. Full construction details for version 1 are given here: http://www.poweramp.ro/forum/download/file.php?id=1 According to the information available, these are the mains characteristics for Version 1:
I will keep this one on my radar screen. ![]() Regards, |
#2 |
#3 |
I do not get this message and besides having a Barracuda system we have a very strict policy in our office - our IT guys are really paranoid about dangerous sites.
I have no clue why you got such a message... |
#4 |
that's because somebody who likes me too much wanted to "help" me in the development of this project. i already traced the attackers, report them and i will fix the problem.
untill then, access just the following link: http://www.poweramp.ro/forum/viewforum.php?f=14
www.connexelectronic.com complete assembled amplifier and SMPS |
#5 |
some test results. photos can speak for themself. on top of the instuments stack, is the Power Analyzer. this measure the input current, voltage, power factor and power. next, the upper scope, the digital one monitor the output vawe, directly on the transformer pins. the lower one, has one channel DC coupled on the bridge, probes set to x10 and scope at 5V/div, 5uS and another channel AC coupled, probes x10, 5V/div, 5us and is connected to vbus. what can see there is the AC ripple. the two multimeters from below the analog scope measures the output voltages, one for positive, one for negative. at the bottom, with the audio analyzer i measure the output voltage ripple at 3, 5 and 6A. the probe is x10, so multiply with 10.
on the other side lays the DC electronic load. because is rated at just 300W, i connected in series 2 power resistors to limit the maximum power, otherwise i cannot load the smps with more than 300W. the current reading is accurate, but the voltage reading should be added to the voltage drop on the resistors, wich is proportional with the current. anyway for accurate voltage reading, i use those 2 lab. multimeters below the scope. i can attach just few photos, for more details, please follow the link http://www.poweramp.ro/forum/viewtop...4&t=2&p=11#p11
www.connexelectronic.com complete assembled amplifier and SMPS Last edited by Cristi; 17th September 2009 at 05:01 PM. |
#6 |
Hello CNX
I am interested in getting the kit you are offering and get my soldering iron going. ![]() I see on the website that it is possible to order the ready-made SMPS with the optional E55 transformer. Is this option applicable for the KIT version? Please advise. Thanks!
#7 | |
#8 |
Hi CNX,
Is it possible to get higher output voltages? Like +/- 60v, any info would be great. Looks really good. Cheers Bowdown
Keep up the DIY spirit!! |
#9 |
the output voltage depends on the transformer turns ratio, output inductor value, capacitor voltage and control loop setting. so, is possible to get any output voltage from let's say +-30 to +-80V by changing this components or without chaning can get +-50V in the range of +-20%.
more infos, and test photos here: http://www.poweramp.ro/forum/viewtopic.php?f=14&t=2 access this link directely, since the main page will throw you to some fake site, thanks to the concurent team which spend time trying virus attacks on my site instead of developing their product.
#10 |
If is an open project, you may wish to share gerber files as we did. :-D
| high power SMPS for amplifiers | ttako | Class D | 3 | 7th December 2008 05:32 PM |
| Audio Nirvana 12 for open baffle project | Octavia | Full Range | 3 | 19th March 2008 03:41 PM |
| SMPS For Valve amplifiers?? | guitar_joe | Power Supplies | 5 | 12th July 2007 02:41 PM |
| Open call for suggestions on Open Source DIY Audio Design | gfergy | Everything Else | 1 | 15th April 2007 07:33 AM |
| Using Monitor power ic as smps for amplifiers | rejithcv | Power Supplies | 10 | 9th November 2006 05:06 AM |
| Page generated in 0.11648 seconds (81.32% PHP - 18.68% MySQL) with 11 queries |
