Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 7th January 2017, 04:41 PM   #2091
Kanutus is offline Kanutus
Originally Posted by Russ White View Post
Take a look at the mpd logs - my guess if you are getting buffer under-runs. You could also tail the syslog and see if your network is dropping out.
Cheers!
Russ
Thanks! I did look at the mpd.log (not sure if there is more than one?), but haven't looked at the syslog. Exactly the help I need, since I'm totally green on Linux ...
Btw: The mpd.log didn't report any errors.
Old 7th January 2017, 04:46 PM   #2092
Russ White is offline Russ White  United States
Russ White's Avatar
No worries, you will be up to speed in no time.
https://www.cyberciti.biz/faq/linux-...ew-logs-files/
messages is where I would look first.
Are you using wired network or wireless?
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 7th January 2017, 04:53 PM   #2093
So this was all in syslog, which doesn't tell me that anything is wrong? Strange date, though? I look into the logs to see if there is anything else ... Thanks again!
Jan 15 06:25:02 botic rsyslogd: [origin software="rsyslogd" swVersion="7.6.3" x-pid="1124" x-info="http://www.rsyslog.com"] rsyslogd was HUPed
Jan 15 06:25:03 botic rsyslogd: [origin software="rsyslogd" swVersion="7.6.3" x-pid="1124" x-info="http://www.rsyslog.com"] rsyslogd was HUPed
Jan 15 06:40:30 botic dhclient: DHCPREQUEST on eth0 to 192.168.0.1 port 67
Jan 15 06:40:30 botic dhclient: DHCPACK from 192.168.0.1
Jan 15 06:40:30 botic dhclient: bound to 192.168.0.104 -- renewal in 1542 seconds.
Jan 15 06:47:01 botic /USR/SBIN/CRON[1506]: (root) CMD (test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.weekly ))
Jan 15 07:06:12 botic dhclient: DHCPREQUEST on eth0 to 192.168.0.1 port 67
Jan 15 07:06:12 botic dhclient: DHCPACK from 192.168.0.1
Jan 15 07:06:12 botic dhclient: bound to 192.168.0.104 -- renewal in 1704 seconds.
Jan 15 07:17:01 botic /USR/SBIN/CRON[1520]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly)
Jan 15 07:34:36 botic dhclient: DHCPREQUEST on eth0 to 192.168.0.1 port 67
Jan 15 07:34:36 botic dhclient: DHCPACK from 192.168.0.1
Jan 15 07:34:36 botic dhclient: bound to 192.168.0.104 -- renewal in 1608 seconds.
Old 7th January 2017, 04:54 PM   #2094
Russ White's Avatar
What is in the messages log?
Audio
Old 7th January 2017, 05:21 PM   #2095
This was the only entry in messages log:
Old 8th January 2017, 07:52 AM   #2096
cmiu007 is offline cmiu007  Romania
@miero: I'm looking to use the cape with a plain mpd install on debian stretchat . my main reason is to have a system as close as it can be to vanilla debian with access to the latest versions.
i have some basic knowledge about linux and I can help to test and generate images for the adventurous types.
at the moment I'm looking for a solution to recompile libasound2 (alsa 1.1.2-1) with your patches. some basic guidance will be apreciated.
@mikelangeloz: for the moment I'm using 2.041 image. is there any progress with mpd test version update because I cannot play dsd files.
kernel: Linux bbb 4.8.13-botic7-rc3 #1 PRMPT Sat Dec 10 01:35:51 CET 2016 armv7l GNU/Linux
alsa lib: Linux bbb 4.8.13-botic7-rc3 #1 PREEMPT Sat Dec 10 01:35:51 CET 2016 armv7l GNU/Linux
mpd: Music Player Daemon 0.19.19
when I want to play a dsd file mpd crashes with
mpd: pcm_misc.c:620: snd_pcm_format_set_silence: Assertion `0' failed.
I presume that I have to recompile mpd?
if needed we can use another thread, forum or private to look into this. please let me know which one do you prefer.
Thank you both for the effort to keep this project alive.
Old 9th January 2017, 06:54 AM   #2097
nautibuoy is offline nautibuoy  United Kingdom
nautibuoy's Avatar
Hello miero. Regarding your mute solution;
Support for Botic Linux driver
I'm sorry to say that I've not had the opportunity to test this yet; it seems that I have a hardware fault on my Hermes/Cronus that the I've not had time to resolve yet.
To enable me to test it I will connect my No-DAC board directly to the BBB header pins and forego isolation and reclocking temporarily. Can you tell me which BBB header pins expose the mute 'signal' please.
Many thanks
Old 9th January 2017, 08:00 AM   #2098
DmKorneev is offline DmKorneev
Hello Miero.
How to bbb-botic-v4-1gb.img.gz write eMMC?
Old 9th January 2017, 05:11 PM   #2099
miero is offline miero  Czech Republic
cmiu007: I'll consider providing compiled MPD against correct ALSA libraries in DEB.
nautibuoy: Please find and recheck my post, it should be written here. Btw, in the next version the parameter will be different, to support both Mute and PCM/DSD switches.
DmKorneev: I'm not able to provide a help with time. No time for this. If possible, don't do this now
BeagleBone Black with I2S, DSD and SPDIF interface (Linux driver)
http://bbb.ieero.com/
Old 9th January 2017, 06:13 PM   #2100
HI! installed bbb-botic-v4-1gb.img on SDcard. Then installed linux-image-4.8.13-botic7-rc3_1_armhf.deb . Got Linux botic 4.8.13-botic7-rc3. But I can not install on eMMC.
I bear command dd if = /dev/mmcblk0 of =/dev/mmcblk1. After this command, the board does not boot.
How to move normally botic7-rc3_1 in eMMC?
Support for Botic Linux driverHide this!Advertise here!
Open baffle with fullrange driver and bass support Godzilla Full Range 5 22nd July 2011 01:32 PM
Low end support for single driver monitors strider75 Multi-Way 97 30th September 2009 03:02 PM
ASIO support (driver) for Labview Aoxomox Digital Line Level 0 3rd May 2009 05:29 PM
Linux/BruteFIR support coming in LspCAD tcpip Multi-Way 18 18th October 2005 03:08 AM
linux badgers Introductions 3 3rd April 2005 03:27 PM
