Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 12th December 2016, 05:33 AM   #2051
mikelangeloz is offline mikelangeloz  Italy
New mpd compiled and up...
However can't get DSD out of my USB DAC (XMOS2 receiver and direct dsd enabled).
Did you set something specific in mpd.conf ?
Old 12th December 2016, 07:48 AM   #2052
twluke is offline twluke  Japan
Support for Botic Linux driver
Hi mikelangeloz,
My MPD configuration is basically adjusted to the I2S connection to the Buffalo 3 and 3SE DACs via either Botic/Hermes-BBB/Cronus or via the USB-I2S connection using Amanero Combo384. Though I'm not using XMOS2, the failure in DSD play after enabling direct dsd may suggest that your current setting is not consistent with playing the source with a native DSD mode. If this is the case, you'll need enabling DoP connection.
In that occasion, playing DSD512 will be impossible and up to DSD256 will be maximum in the current linux USB audio. In fact, my Amanero board with USB-I2S connection on Botic system is only playing DSD up to 256fs with the latest Amanero's firmware but no more and the developer is on the way to get higher resolution.
BTW, shown below is my alsa configuration in /etc/mpd.conf:
Code:
audio_output {
        type            "alsa"
        name            "Botic"
        device          "hw:0,0"
        dsd_usb         "no"
        dsd_native      "yes"
        dsd_native_type "3"
#       priority        "FIFO:32" #not supported on mod-0.20
        period_time     "1"
        mixer_type      "software"
#       mixer_device    "default"       # optional
#       mixer_control   "PCM"           # optional
#       mixer_index     "0"             # optional
audio_output {
        type            "alsa"
        name            "Amanero"
        device          "hw:1,0"
        dsd_usb         "yes"
        dsd_native      "yes"
        dsd_native_type "2"
        period_time     "1"
The setting above is based on the mpd.conf included in miero's botic system and is probably deriving from lintweaker's DSD with realtime option setting because he was the main developer of DSD support for mpd. After solution of endianness (BE or LE) in native DSD by mpd-0.20, it appears that he has ceased his work in DSD.
Old 12th December 2016, 09:10 AM   #2053
miero is offline miero  Czech Republic
Originally Posted by Mull3t View Post
Maybe I'm misunderstanding, but if I use the sancloud based dtb then wouldn't I disable the botic driver? That is not my intention.
Please test if it boots properly. Then I'll consider creating an Botic overlay that would fit to all variants Black/Green/Sancloud...
BeagleBone Black with I2S, DSD and SPDIF interface (Linux driver)
http://bbb.ieero.com/
Old 12th December 2016, 10:55 AM   #2054
mikelangeloz: standard alsa in debian stable does not support DSD or high sample rates
I prepared a patched ALSA library, that must be installed before MPD is built:
- Index of /botic/pool/main/a/alsa-lib
In case you want to rebuild also this ALSA library, a updated kernel header /usr/include/sound/asound.h is also needed, that defines DSD formats.
Old 12th December 2016, 11:01 AM   #2055
Thank you very much miero!
Old 12th December 2016, 11:13 AM   #2056
Uh well, thank you miero for this supportive info.
Mikelangeloz, I'm sorry to say that I've forgotten to address that my mpd-0.20 build was performed on debian stretch (testing).
Old 12th December 2016, 01:35 PM   #2057
Mull3t is offline Mull3t  United States
I can confirm that my BBE now boots properly with either dtb.
Based on some probing with dmesg, I had to add these drivers/firmware for the BBE:
rtl8723b_fw.bin
rtl8723bu_nic.bin
I'm still getting the omap-sham, LSB: IPv4 DHCP, and dhcpd.service errors. I get them on the BBB revC as well, so I'm assuming this is normal.
When I switched to the sancloud-bbe.dtb I was able to connect to volumio.local. So DHCP appeared to work. I didn't get to test the same thing with the boneblack-botic.dtb.
When I connected to volumio.local I wasn't able to mount my Synology NAS mount even with proper login*** and path.
Looks like we're getting somewhere...
Old 12th December 2016, 07:01 PM   #2058
PET240 is offline PET240  Australia
So am I assuming there will be another update to come for bbb and Botic 2 with the Alsa updates?
Had enough fun configuring botic 5, no linux genius here.....
Thanks so much for your efforts gents! Outstanding!
Old 14th December 2016, 02:12 AM   #2059
So it appears that I can connect to volumio.local when using the BBE .dtb, but not the BBBotic .dtb. What is the difference between the two? I guess I'll wait til miero works his magic and includes the special sauce to get it working.
When I look at /etc/network/interfaces on both my BBB revC and the BBE, they have the same settings. So eth0 should be getting DHCP. However, when I use ifconfig to look at settings Eth0 doesn't contain useful info. I also tried setting a static ip with appropriate settings and that didn't work either.
Thanks!
Old 16th December 2016, 03:51 PM   #2060
yanpetr is offline yanpetr  Russian Federation
Miero, Mikelangelo, hello!
please tell me how to fix the problem with the volume control in the cantata on Volumio2
In the version of Miroslav - this function works done!
many thanks
Support for Botic Linux driverHide this!Advertise here!
Open baffle with fullrange driver and bass support Godzilla Full Range 5 22nd July 2011 01:32 PM
Low end support for single driver monitors strider75 Multi-Way 97 30th September 2009 03:02 PM
ASIO support (driver) for Labview Aoxomox Digital Line Level 0 3rd May 2009 05:29 PM
Linux/BruteFIR support coming in LspCAD tcpip Multi-Way 18 18th October 2005 03:08 AM
linux badgers Introductions 3 3rd April 2005 03:27 PM
