#381 | |
Output of buffalo is loaded with either 2pc of 2.7Ohm or one 2.7Ohm wire with ground in the middle into the transformer, yes? This is the best way, linestage not involved in the 2.7Ohms?! Because the secondary is always floating, you can choose what to do. How have you come to 1.85k with the Lundahl? Did you already check if the Lundahl can do it? |
#382 |
Output would be loaded with 2 x 2.7R resistors (one for each phase), and GND in between them.
How i come up to approx 1.85K impedance is because i have calculated it. LL1933 should work according to Lundahl (up to 50mA) and does have primary impedance of 0.8R per winding, and 85R on secondary. So on the primary side i have 5,4R + transformer 1,6R. Transformer ratio of 1:16 equals 256x impedance ratio. so 7x256 = 1792ohms plus the impedance from the secondary 85/2=42,5R (since they are paralelled) so in total 1834,5R simple as that. What i may have done wrong with the above calculations is that i'm not shure if the the loading resistors would "seem" in paralell for looking from the secondary of the transformer. If it would be that way, then impedance would only be 938,5R. Anybody that can calarify this? Also one last thing, would it be better having the primary floating (center tap not connected to GND) or would it be better to connect it straight to ground? Also, when running outputs directly from dac to transformer, wouldn't there be any issues with DC-offset? i'm just thinking if coupling cap would be needed for transformers that cannot take DC? |
#383 | |
#384 | |
Thanks.
![]() Quote:
Whether using step-up or 1:1 Txs, that Z on the Primary needs to be as low as possible - and it benefits BOTH the DAC and Txs. But in your case, step-up makes it even more important as I see it. I suspect that using a step-up transformer with 1K on the Primary is not so good because the source Z of the DAC is way too high into the Primary. In that case a step-up transformer would indeed sound "broken" - so the Lo Z is also good for step-up transformers as the need that Lo Z on the Primary may be even greater with step-ups. And that Z can be lower than 1:1 - so do it. It really doesn't matter what the Tx post-DAC solution is (if using Txs), the basic rule is the same. Get the Z on the Primary as low as possible, and don't worry about grounding the Sabre DAC - and that passive I/V is the way to go, even partially loading down 1:1 Txs. It just comes down to whether you have enough output. Even with non-Tx solution, Lo Z passive I/V is the way to go. But here the benefit is only to the DAC and very important too. But using Txs, they should always sound better with Lo Z on the Primary. Hope I haven't sounded to repititious. Cheers, Joe
The "Elsinore Project" DIY Speaker System Webmaster: Custom Analogue Audio, JLTi and... "The Linear Current Loudspeaker" |
#385 |
According to Lundahl at least does the transformer resistance count into total impedance, and logically i do not see why it wouldn't?
Anyway, have i understand right that from the beginning you just had a 1,2R "resistor/wire" between the positive and negative phases, and then you split it connecting the "middle" to the transformer Center Tap? but you did never connect to DAC-GND? Which of these solutions did you use? ![]() Joe: did you see my questions at post #380 Last edited by RollE2k; 10th December 2012 at 09:18 PM. |
#386 |
Only connect the Ground to the centre of where the resistors meet. Connect nothing to the transformer's centre tap. You do not want any potential DC to go through the transformer - the DC resistance of the Primary (or any part of it) must not be in parallel with the resistors, or else some DC current will flow through that part of the Primary. You was all the DC current to go through the resistors, to ground. If the two resistors are well matched, then both extremities of the Primary will sit at the same voltage. That means no DC current through the Primary of the transformer. Is that clear enough? Re Secondary. In theory, best not to be grounded. Especially not grounded when balanced used in balanced mode. If unbalanced, then still best to let it float at the transformer end (if possible or practical) and ground at the receiving end, whether that be a pot/volume control or not. That way you get "galvanic isolation" - that is that the ground of the DAC is isolated from the ground of the preamp or whatever is at the receiving end. Isolating grounds are good in principle. Cheers, Joe
The "Elsinore Project" DIY Speaker System Webmaster: Custom Analogue Audio, JLTi and... "The Linear Current Loudspeaker" Last edited by Joe Rasmussen; 10th December 2012 at 09:33 PM. |
#387 | |
But what is the cap for, the 0.33uF one you had between positive and negative phases? Also when running primary side this way and you look from the secondary side (1:16). Does the reflected impedance look like (2,7+2,7)x256=1138,4R or (2,7/2)x256=345,6R - that is, do they look like series OR parallel? |
#388 |
Please note that was a NON-transformer solution. That cap was specific to that circuit and not transformers. The transformer is a bandpass filter and does not need the cap.
Cheers, Joe
#389 | |
#390 | |
Transformers works at their best when driven from a low impedance. The output impedance of the Sabre DAC is quite high, many times higher than voltage DACs. So the low impedance cannot come from the DAC itself, it in a sense has to come from the Ground. Simple as that. (Current type DACs like B-B does this naturally as the have a very high output Z and relies on Ground to make it low). And Sabre DACs are also at their most linear when seeing a Lo Z current mode. The usual "common garden" solution is to use an opamp with a Virtual Ground approaching Zero Ohm. But this is a feedback trick. Normally with "current" DACs with DC voltage offset, this means that the Zero Ohm has to actually float at the same DC voltage offset of the DAC (usually 1.65V). But the Sabre DAC is very different beast, it has a fixed output Z of 780 Ohm. Paralleling four phases will give you 195 Ohm combined, eight will give you 97 Ohm. These are all relative high - not good for Txs. But ahh... that output impedance also acts as a current limiter when shortened to ground, and in the Sabre DAC means we can do something we cannot do with any other DAC: Pull it to Ground! The DC offset current is 1.65V/780R = 2.1mA per phase. It cannot go higher than that - so we use that to advantage. We can now construct a near REAL EARTH rather than a Virtual one. The downside? Only slightly more heat generated by the DAC's outputs and that about 3.5mW phase per side. Negligible. In total about 50mW. The DC offset current we have created must go through the resistors and not the transformers. The resistors should also be 1% or better matched. Cheers, Joe
| Thread Tools | Search this Thread |
| Buffalo II | Russ White | Twisted Pear | 1820 | 7th February 2013 06:48 PM |
| Volumite for Buffalo II? | markusA | Digital Line Level | 15 | 8th April 2010 02:51 AM |
| Need help selecting an I2S/DSD/SPDIF connector for my impending Buffalo II | orpheus | Digital Source | 0 | 9th February 2010 08:03 PM |
| FS- Twisted Pear Buffalo 32S Board & System New & Unused | secretriches | Swap Meet | 1 | 10th August 2009 02:17 PM |
| Citation II output transformers | dshortt9 | Tubes / Valves | 10 | 12th December 2003 03:45 PM |
