Go Back   Home > Forums > > >
Twisted Pear Superior quality electronic kits
Old 23rd March 2010, 04:51 PM   #211
arthur is online now arthur
Buffalo II
Default ivy3
Hi Brian,
Thanks for your answer.
Can i simply use the opa1632 balance output stage to connect to a unbalance preamp input(+ve pin and gnd pin), as the driving power of 1632 is better?
Lastly i want to buy Joshua Tree kits from your homepage but everything is out of stock
Arthur
Old 23rd March 2010, 09:02 PM   #212
steve jones is offline steve jones  United States
steve jones's Avatar
Default ES9018 heat?
Was wondering how warm/hot the Sabre chip runs on the Buffalo II PCB?
Was intending to mount it bottom side flush (with reliefs cut for misc capacitors and inductors) on a piece of spruce like my Attraction DAC.
Russ, any opinion if this would overheat the chip or not?
Old 24th March 2010, 10:53 AM   #213
Spirit02 is offline Spirit02  Peru
Mine has arrived too
Estimated delivery time: 6 days
Actual delivery time: 3 days
Construction will start next week after I finish a couple of assignments...
Old 24th March 2010, 11:24 AM   #214
acidbrain is offline acidbrain  Netherlands
acidbrain's Avatar
Buffalo II
Received mine without TAXES !
Old 24th March 2010, 05:16 PM   #215
io is offline io  Hungary
also Received mine without TAXES !
Hungary
io
Old 24th March 2010, 05:20 PM   #216
Hungary
io
Old 24th March 2010, 06:04 PM   #217
muizel is offline muizel  Netherlands
muizel's Avatar
Hi Eric,
Super that you have him allready I am also in the nethetlands, what was your shipping date ?
Greetz René.
Old 24th March 2010, 06:16 PM   #218
fierce_freak is offline fierce_freak  United States
Send a message via ICQ to fierce_freak Send a message via AIM to fierce_freak Send a message via MSN to fierce_freak Send a message via Yahoo to fierce_freak
Anyone using transformers for output? If so, I'm curious to see your scheme or parts choice.
Old 24th March 2010, 07:20 PM   #219
I've got a custom 48% nickel core pair ordered from Bud Purvine at Onetics. The primary will simply be connected between + and - outputs (for each DAC channel) and primary's center tap left floating.
1:1 ratio for a single ended output voltage of around 3.03V peak to peak dependant upon AVCC voltage. Or ground the secondary's center tap for a balanced output.
Simple. Hopefully not too much so.
Old 24th March 2010, 07:36 PM   #220
Joshua_G is offline Joshua_G  Israel
Joshua_G's Avatar
Can you link please to those trafos?
Buffalo IIHide this!Advertise here!
Buffalo Tweaking jkeny Digital Line Level 316 10th March 2010 09:14 PM
Hello from Buffalo NY chris emo Introductions 1 13th July 2007 04:24 AM
Buffalo brains macmeech Introductions 1 15th June 2004 06:03 PM
