Go Back   Home > Forums > Commercial Sector > Manufacturers > Twisted Pear
Twisted Pear Superior quality electronic kits
Old 18th October 2009, 03:27 PM   #61
Russ White's Avatar
Send a message via Yahoo to Russ White
Paul what you are seeing is normal. You can readjust both the CCS and the output voltage slightly after the heat sinks are warm. The warm output current will always be just a bit more than it will be cold.
You can decrease the CCS current to just what is needed by turning it down until output starts to sag while connected to the load, then turn it back up a few turns after it comes back to the desired voltage. Now you will have just a bit more current than you need.
By tuning the supply to just what you need you will generate less heat.
Cheers!
Russ
Less pulp more juice Twisted Pear Audio.
Old 18th October 2009, 09:09 PM   #62
mourip is offline mourip  United States
Originally Posted by BrianDonegan View Post
Shunt regulated supplies generate a lot of heat. You must be sure to provide enough ventilation. This alone is a good reason to space them out a little bit. After the supply is at operating temperature, and readjusted, the voltages should remain stable.
PS: I deleted the duplicate post on our support forum so that answers can be found.
Thanks for the reply. I posted in both forums because I had been having trouble reaching you this week when replying to the email you sent out asking for feedback on the Placid. Glad to catch you here...
Today the voltages started out at about 15.5 volts and gradually dropped close to where I reset them yesterday after they had drifted up over a two hour time period. I am letting them settle in and will tweak them once more.
Thanks for comfirming the heat dissipation observation. If someone is looking for a drop-in replacement these might not work for some boxes. I have a Parmetal case with good venting and still my entire box warmed up.
Regarding adjusting the CCS. Are there any other points where a voltage could be taken off? How about the un-populated pads for R1/R2? Would the voltage drop across these two points be directly proportional to the drop across R17/18 when the CCS adjustment pot is changed?
The good news is that the DAC sounds great....
Old 18th October 2009, 09:25 PM   #63
Russ White's Avatar
The voltage reference has a negative tempco. So it will tend to start up slightly higher than it will be at working temperature. So what I usually do is adjust for just under your target voltage. That way you never exceed you desired output voltage.
The movement is not very much and the less you heat the VREF section the less drift there will be. So I would adjust the CCS to deliver just what you need with a bit of overhead for the shunt.
I will edit the manual to makes this clear.
I am glad you are enjoying the DAC.
Cheers!
Russ
Old 24th October 2009, 07:36 PM   #64
Russ
Just to clarify for my own understanding. According to the manual "The output current per rail is calculated as V across RE divided by value of RE where RE is either R17 for the positive rail or R18 for the negative rail.
So... if I adjust to the .25v suggested in the manual and R17/18 is 1ohm per the BOM then I must be running my supplies at .250A. If I want to get them down to ~.150A then I would adjust down to ~.15v.
Is that correct?
Old 24th October 2009, 09:27 PM   #65
BrianDonegan's Avatar
Yes.
Twisted Pear Audio
Old 29th October 2009, 01:29 AM   #66
frugal-phile(tm)
planet10's Avatar
Discussion moved here
CCS in Placid-BP Bipolar Shunt Regulated Power Supply
Old 29th October 2009, 07:52 PM   #67
NicMac is offline NicMac  Italy
NicMac's Avatar
Hi All,
I just tried a set of the Placid supplies with a "stock" Buffalo24, with IVY II, and the improvement is very noticeable. I would like to try them also with my Buffalo32S but this unit is a bit "over-tweaked" for a fair comparison between the Placid's and the LCDPS/LCBPS.
Nic
Old 29th October 2009, 07:57 PM   #68
avr300 is offline avr300  Denmark
avr300's Avatar
Originally Posted by NicMac View Post
Hi All,
I just tried a set of the Placid supplies with a "stock" Buffalo24, with IVY II, and the improvement is very noticeable. .............
Nic
Hi Nic.
Powering the IVY ?
Join http://TurnMeUp.org
Old 29th October 2009, 07:59 PM   #69
IVYII only exists on B32. I think he means IVY 2.0. Yeah, that's much more clear...
Twisted Pear Audio
Old 29th October 2009, 09:05 PM   #70
NicMac's Avatar
OK, with an IVY 2.0 (actually moderately tweaked according to TPA instructions). I only have the honor of Sir IVY the 2nd on the B32
Anyway, I did first the change of the VA supply and then afterwards the VD. The change was definitely most evident with the VA supply. I will not test much more with this configurations as I have the Counterpoint I/V that I find quite a bit better than the IVY 2.0. I just have to check a few thing with current draw etc.
Nic
Shunt-regulated 24V DC Power Supply for Preamp Modules snoopyma Power Supplies 31 16th January 2010 03:05 PM
Bipolar Power supply IC argonrepublic Parts 1 6th December 2008 07:24 PM
Regulated Power Supply. Bipolar, JFET or MOS? Kenneth Zhu Tubes / Valves 4 30th December 2007 08:30 AM
Shunt-regulated 24V DC Power Supply for Preamp Modules snoopyma Solid State 0 25th August 2005 04:58 PM
power supply: shunt or series?? AudioGeek Solid State 34 25th July 2004 02:02 AM
Page generated in 0.11680 seconds (81.60% PHP - 18.40% MySQL) with 11 queries
