Buffalo DAC (ESS Sabre 9008)
npapp said:
so the CT transformer leakage inductance is 0.5uH...is this a usable range?
The Newava transformer that Russ and Brian use has a leakage inductance of 0.3uH.
Then as far as I know - which is not much - best to go for 0.3uH
I managed to buy nuwava transformers in USA in small quantity no problem - sorry cannot recall where just now.
Hi!
I've measured current from audio outputs of Buffalo and it is "only" 6mA (it should be 8mA). Is there something wrong - configuration, how pins are connected? I do not have datasheet (although NDA signed was sent, but they did not reply) to check this out.
Matej
Russ White said:
PCBs (and likely kits too) are available for anyone who has balanced gear and wants to give it ago.
I would not use it directly out single ended because you will get a turn-on and turn-off thump.
I would like to try this. I'm using the buffalo with great pleasure. My wife questioned me thoroughly what I had changed that made piano sound so much more real... :D
Currently I'm listening to a the following setup (see pic):
CD-Pro2M --> buffallo (over spdif) --> IVY --> relais attenuator (home made, not balanced) --> Hypex UCD400.
I would like to skip the attenuator completely and go from buffalo to I/V stage to UCD fully balanced. Volume would have to be controlled digitally in the DAC of course. This, I still need to program into a PIC...
Analog sources like radio (low quality anyway) would need to be converted to digital first and would travel the same route afterwards.
Where to order?
So TPA team: Thanks for the hard work!!
Lennert
This sounds like a job for the Volumite!
We have a plan around this, actually. It will remain top secret until it's a little more formed.
Yes, and actually I'm awaiting its awailability... I could than maybe even use the Uber controller to control the CDPro...
If you tell me here ... I'm sure nobody will find out :)
(but seriously, I can live without analog sources for quite some time the buffalo sounding the way it does...)
woodturner-fran said:
Russ,
when do you think the counterpoint kits will be available?
Fran
Honestly I need to test it further before I release. I am waiting until I have a couple placid power supplies sin my hand to test with before I do much more testing.
I am still getting some nagging buzz which I think may be a GND loop, but I need to be sure I have the design solidified before I turn it loose.
I would be willing to send some "beta" boards and the latest schematic to people who have the time and know-how to help me perfect Counterpoint. It could be I am missing something that will be obvious to someone else.
If anyone here is interested please contact me by email.
Thanks!
Russ
192kHz S/PDIF
So, just finished testing a Buffalo with the updated comparator in place. I get solid lock at 24bit/192kHz S/PDIF.
Since I don't have a true 192kHz source, my test rig used a Metronome to upsample a 16/44.1 signal to 24/192 I2S, which was then fed through a WM8804 module to transmit the S/PDIF to the Buffalo.
Future Buffalos will use the new comparator.
Sounds awesome, so when are the new Buffalo boards going to be available again? :)
Also how about the Counterpoint?
On another side note, the USB receiver - what level is the I2S signal from it? 3.3V or 5V? I was looking at the PCM2707 datasheet and I couldn't find a clear answer on that so I'm wondering if you know.
This is a side project for the North Star m192 DAC that I have which accepts I2S input (which also makes me think hello Metronome :cool: )
