Conrad Johnson PV 7 problem
Old 6th November 2006, 12:58 PM   #1
Peppe is offline Peppe  Italy
Unhappy Conrad Johnson PV 7 problem
I have a problem in my C-J PV7, it sometimes turn off and restart automatically. It means that I must wait 45 seconds about (warmap time) before the music restarts.
It is possible that the SPRAGUE capacitors (TVLU 1095) in the PSU are exhaust?
Someone got the schematics?
Thanks in advance
Old 6th November 2006, 02:52 PM   #2
The cap on the left is Spraugue TVLU 2925, are they still in production?
Old 6th November 2006, 04:24 PM   #3
On Hiatus
SY's Avatar
You can certainly still find equivalent Twist-Lok electrolytics, but at the cost of not being "vintage," one can replace them with more modern caps of the same capacitance and voltage. Look for 105C rated capacitors. You'll be surprised at how much smaller we make them today.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 6th November 2006, 04:44 PM   #4
Thanks SY,
do you think my problem are the caps?
Do you have a favorite Twist-Lok capacitor producer?
Cheers
Old 7th November 2006, 10:32 PM   #5
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
In my experience, Conrad Johnson will email you a scan of the schematic if you ask them nicely.
When asking for schematics it normally it helps to give the serial number as proof of ownership.
Old 7th November 2006, 10:43 PM   #6
On Hiatus
SY's Avatar
Originally posted by Peppe
Thanks SY,
Cheers
Possible, and I'd replace them anyway, but it's more likely in the soft-start/mute circuit or the regulator. But bad caps can still be the root cause.
I don't like Twist-Loks in general, so that's like asking me about my favorite rap artist.
Dhaen's point is well-taken: get a schematic, and troubleshooting will be much easier.
Old 7th November 2006, 11:41 PM   #7
moamps is offline moamps  Croatia
Hi Peppe:
You can find the schematics of the PV6 and PV10 versions here
http://www.drtube.com/audioamp.htm . The schematics should give you a pretty good clue as to your preamp.. From what I can tell, mulfunction may be somewere on the primary side of the transformer (if the "pilot" lamp turns off at the reset moment) or inside the "delay output on" circuitry.
Milan
Old 7th November 2006, 11:45 PM   #8
anatech is offline anatech  Canada
anatech's Avatar
As I recall, they were using film caps for the B+ filter. Lower value of course. Also, every CJ I've looked at had the heater filter cap opening up. Check that first.
-Chris
Old 8th November 2006, 09:37 AM   #9
Ok, I'll try and will report the result...
Sure, I will try to find the caps anyway
Yes, the led turns off at the reset moment.....
All suggestion are very important for me. It's my first time I decide to repair a my object, I just finished my first DIY-job (Aleph30) and now the pre decided to stops working......ARGH!
Maybe I will ask a friend of mine to help me in this job....
I want to thanks very much all you guys for suggestion
Peppe
Conrad Johnson PV 7 problemHide this!Advertise here!
Conrad Johnson Premier 10 Freddie Tubes / Valves 2 19th March 2013 09:45 AM
Conrad Johnson Premier 350 Tube_Dude Solid State 0 30th January 2009 07:49 PM
Conrad Johnson PV10 mod hbarki Tubes / Valves 7 23rd July 2007 04:33 AM
Conrad Johnson MV 45 schematic help 845 Tubes / Valves 1 21st December 2005 05:39 PM
conrad johnson help efoda Tubes / Valves 3 24th January 2002 04:23 AM
Copyright ©1999-2017 diyAudio
