Some are here:
Hey Airhead, can you describe what and which those tube amps are? Looks very interesting and quite a lot work.
Is that a 6L6 PP to the right?
On the back row is a pair of SE SV572-10 monoblocks based on VTV magazine article. I made few improvements which I think improve sound quality and reliability. Driver is 6EM7. I replaced output irons to Lundahls since this pic was taken.
In the next row is basic SE 300B power amp made using some Dutch transformers, 6SN7 driver. All caps in power supply and amp circuit are polypropylenes. In the middle is SRPP 5670 linestage with tube rectifier and stepped attenuator, it´s made on Chinese PCB:s. And yes, next machine is PP 6L6 integrated, basic design is from Glass Audio article written by Joseph Norwood Still, I made many improvements, better quality components, CLC-filter with polyprops, shorter signal path (input selector is near RCA-connectors, assemled in a long rod) etc.
Next in the pic is 6SN7 linestage loosely based on the VTV article, AC filaments and quality components that I allways use. Then there is integrated with KR300BXLS tubes, all polypropylene PSU and Audio Note OPT:s, polyprop cathode bypass on power tubes, totally solid state free design. Next to it is Hagtech Cornet Classic phonostage made by extremely HQ components (Auricaps, Dales, Elnas, Rifas).
In the front is my oldest build, circuit board phonostage with three 6DJ8´s, regulated solid state PSU, WBT connectors, teflon wiring and so on. At last there is passive pre with quality connectors, teflon wire, rotate switch and Alps pot.
Attached a pic of KR300BXLS integrated underneath the bottom plate.
wow, that looks like a fine collection
Thank you very much!
GU-50, more power than KT-88, true pentode design. Preamp my own proprietary design, a mix of solid state and tube. Stunning clarity and powerful enough to drive 15-inch active-passive bass module. The other is 6L6GC running midrange and treble.
H Jerry... Can you please be kind enough to provide me the link to a good sounding PP GU-50 schematic?
Thanks!
I PM'd you.H Jerry... Can you please be kind enough to provide me the link to a good sounding PP GU-50 schematic?
Thanks!
Reference line preamp
My new build, schematics provided by Alex Kitic.
It's a line section pre-amplifier with 3 tubes, an EZ80 and two 6189W (ECC82).
In the audio section there's only one cap per channel.
It has a CLCRC power supply.
5 inputs, an Alps potentiometer and a 'HB Amp Design' custom wound toroid power transformer. Designed and build the housing myself.
The design allows placing inside furniture, because there's not too much heat generated and there are no tubes on top.
The power amplifier on the picture is my previous build, the RH Universal, schematics also from A. Kitic.
Very good work , inside and outside .SE SV572-10 monoblocks. After the pics has been taken, OPT:s are replaced with Lundahls.
Thank you very much. My hands are itching for an new project, have not yet decided the schematic.
Let me guess , will it be an 211 based amp ? .Thank you very much. My hands are itching for an new project, have not yet decided the schematic.
I am working on an hybrid amp now , tubes and IGBTs .
- Tubes / Valves
- Photo Gallery
