FWIW, I strongly prefer LR8 regulation, with an IC dedicated to each channel. Take all legitimate steps to minimize residual hum. Separate regulators improve channel separation.
While AC heating is possible, don't go there. The challenge is TOUGH, for a very experience builder. Build a proper, regulated, 12 V. DC heater supply. You need 300 mA. of 12 VDC current. Voltage doubling 6.3 VAC requires a filament winding capable of 1.2 A. TANSTAFFL! An example DC heater supply is provided. The same topology with different parts is what you use in the B+ PSU.
Thanks! The transformer that I have has a 6.3v secondary at exactly 1.2a so I assume I can use that and build both heater and B+ supply in the same box?
Correct.
So I have ordered the parts for Eli's version of the RCA phono stage. In the mean time I put together the PSU and just for the entertainment and educational value I put together the schematic that I originally posted because I had those parts. Anyway I am shocked. It has issues but in a lot of ways sounds excellent!! It is quiet, awesome detail and resolution, good soundstage but the trouble is there is virtually no bass. Either that or the HF is overpowering it. It has a ton of gain in fact way too much. I actually see potential in this thing. Does anyone have any suggestions on what may be causing too much gain, too much treble and lack of bass? Maybe this could be the start of a really good sounding pre.
- Tubes / Valves
- Tube phono stage build
