Vacuum Tube SPICE Models
Old 30th November 2013, 05:27 PM   #101
euro21 is offline euro21  Hungary
Originally Posted by needtubes View Post
Found some here, but they do not work with my LTSpice generic TRIODE model
Please read this: :: View topic - Drop Down Menus for selecting your tube
Old 30th November 2013, 05:52 PM   #102
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Originally Posted by jazbo8 View Post
Here you go...
thank you !
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 30th November 2013, 05:58 PM   #103
jackinnj is offline jackinnj  United States
jackinnj's Avatar
Old 1st December 2013, 01:15 PM   #104
RajkoM is offline RajkoM  Bosnia and Herzegovina
RajkoM's Avatar
To create your own spice model, the first step is the determination of MU from a reliable diagram. Diagram must include Ug=0V curve.
I took Telefunken pentode and triode diagrams just for example.
The formula for calculation is:
MU=(Ua-Ua min) / Ug
For pentode, the line passes through operating point and the END of knee @ Ug = 0V, as you can see.
Old 1st December 2013, 04:03 PM   #105
kevinkr's Avatar
Thanks Raj,
This will allow us to determine mu for the model and then work solely with the other parameters - should make curve fitting a lot easier.
I built a prototype of my new phono stage (the muscovite mini) using a 6Z9P-E pentode in the front end and was gratified at how close the measured performance was compared with the spice model predictions. It even sounds good.. lol (The model is a slightly modified version of the one you gave me, kg2 adjusted to reflect real world screen currents.)
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 1st December 2013, 05:57 PM   #106
RajkoM's Avatar
Originally Posted by kevinkr View Post
Thanks Raj,
I saw, nice.
I know a few DIYers who use E180F in RIAA preamp.
One of them has E180F in pentode mode as input, and E180F triode mode on output (LED bias, CCS mu-out). He is very happy with sound. I adapted the Russian Teflon capacitors for his RIAA RC network. Simply unwrapped AL/Teflon foils to the required value. See atach.
Old 2nd December 2013, 02:01 PM   #107
Zen Mod's Avatar
well , I'm dumb .... but that's hardly anything new .....
what I'm doing wrong ?
current from PSU to tube is 8A , but I'm still puzzled where is it going
Old 2nd December 2013, 02:43 PM   #108
RajkoM's Avatar
Kad tvoj atas proslijedim u LTspice, sve je korektno. Radna tacka: 395V/99,4mA/-11,93V,
Tako da trenutno ne bih znao.
translation:
When your atach I put in LTspice everything works correctly.
So currently I do not know ....
Old 2nd December 2013, 02:47 PM   #109
RajkoM's Avatar
I think I know what it is. In Ayumis model put to be A G K, not P G K.
It should be like this:
. Subckt SRS511_T A G K
syntax, a common problem in LT spice
Old 2nd December 2013, 03:37 PM   #110
Zen Mod's Avatar
tnx Rajko
can you zip and attach here functional sim , along with all needed files ?
even when I change that line ( as you wrote in #109) there is something wrong
I know , main problem is still - short circuit between headphones of operator
Vacuum Tube SPICE ModelsHide this!Advertise here!
Vacuum tubes SPICE models, another way Dominique_free Software Tools 2 12th November 2013 06:26 PM
Tube spice models nhuwar Tubes / Valves 45 25th November 2011 08:47 AM
Computer program for tube curves and Spice models Jim Tonne Software Tools 9 21st November 2010 10:10 AM
Got my tube spice models, and tubed CD player page back on the air wa2ise Tubes / Valves 2 20th April 2008 11:07 PM
