Old 9th April 2012, 07:18 PM   #21
SY's Avatar
Originally Posted by tubelab.com View Post
A tiny voltage change on the cathode will affect the bias on the tube causing a bigger than normal change in current through the tube.
Let's throw some numbers at it. We can examine the input stage to a power amp using voltage amp -> split load inverter, since that's where you're likely to have the greatest swing. A 12AT7 is a common choice, so let's go with that. Put 120k on the plate. So to get 20V of swing, the current change is 0.16mA. The input voltage will be something like 0.4V.
Now, one can swamp any current changes in the LED by using my resistor-from-B+-to-cathode trick, but for the sake of discussion, let's not. The AC impedance of a red LED will be on the order of 7R at a "normal" plate current for 12AT7. So the voltage swing across it will be about 1.1mV, which is about 0.25% of the input voltage. If the LED nonlinearity at that tiny current swing were 10% (it's not), we're talking about 0.025% added distortion, which is considerably smaller than that contributed by the tube. The actual number will be even smaller.
If we do my resistor trick so that the LED current is 10mA, the impedance is now 4R. So we've dropped the added distortion by nearly half. And at smaller signal swings, the effect of the LED nonlinearity gets even smaller, as is true with higher plate loads. Thus the crazy-low distortion of my phono stage.
If there's a sucker born every minute, where do the rest of them come from?
Old 9th April 2012, 08:03 PM   #22
M Gregg is offline M Gregg  United Kingdom
M Gregg's Avatar
OK,
So how does that compare with a resistor in place of the LED?
M. Gregg
What is the sound of one hand clapping?
Old 9th April 2012, 08:10 PM   #23
SY's Avatar
Lower distortion, higher gain, lower output impedance. Compared to bypassed resistor, faster recovery from overload, flat response to DC.
Old 9th April 2012, 08:21 PM   #24
M Gregg's Avatar
What can you say to that?
This has also confirmed my findings with the better drive.
M. Gregg
Old 10th April 2012, 10:50 AM   #25
CSlee is offline CSlee  United Kingdom
Clueless
CSlee's Avatar
Can you explain this trick please? Do you have a reference somewhere that I can look at?
Charlie
Broke solderer with delusions of grandeur
Old 10th April 2012, 11:10 AM   #26
SY's Avatar
I've posted it a few times before (and I notice that it has found a place in the latest edition of Valve Amplifiers); it's pretty self-explanatory, and I don't claim originality. Just run a resistor from B+ to the cathode to get a higher LED current. For example, let's say you have a red LED (1.7V) biasing a 12AX7 stage running 1mA, with a 200V supply. To get the LED to a flatter part of the Vf versus If curve, you might want the LED to have 10mA running through it. We supply the extra 9mA from a resistor, which can be calculated by Ohm's Law- R = V/I = (200-1.7)/0.010 ~ 200/0.01 = 20k.
As a practical matter, I haven't seen much difference when the plate loads are reasonably high (i.e., running close to constant current).
Old 10th April 2012, 11:12 AM   #27
Originally Posted by M Gregg View Post
OK,
M. Gregg
You need to bear in mind that the a resistor is not a direct replacement for the LED. A LED is functionally eqivalent to a resistor plus a bypass cap, typically an electrolytic.
So - a resistor (unbypassed) in the cathode provides local feedback and reduces gain. Bypassing resistor with a cathode will retain same quiescent bias point, but will tend to reject signal voltage changes, hence providing a psuedo voltage source - so no local feedback, higher gain but also higher distortion, due to reduced feedback and capacitor non-linearities. A LED mimics the voltage source (assuming small dynamic impedance), retaining the gain of the bypassed resistor, but ditching the yucky electro. So for tubeheads who say that they don't want semi-conductors in their circuits, the options are a battery or an electro bypass cap. A simple unbypassed resistor is NOT equivalent.
Old 10th April 2012, 11:18 AM   #28
Clueless
CSlee's Avatar
Thanks, I look forward to VA4 coming out again so I can read up on it.
Old 10th April 2012, 12:23 PM   #29
Tony is offline Tony  Philippines
Tony's Avatar
i blame it all on SY, now i use only led's on my small tube amp cathodes....
i still do use resistor/capacitor combo on my guitar amps......
Old 10th April 2012, 01:10 PM   #30
TheGimp is offline TheGimp  United States
TheGimp's Avatar
Likewise, I've run 6N1P, 6N2P, 6N3P, and 6N23P with LED bias and current source as anode load and the distortion figures were consistently lower than the equivalent biased resistor load, resistor or resistor and cap in cathode circuit.
I used both HP spectrum analyzer and PC with sound-card for distortion measurements and to look at harmonic distribution.
LED's jim5763 Swap Meet 3 21st February 2010 01:04 AM
300B Cathode Feedback + Cathode Bias korneluk Tubes / Valves 13 7th January 2009 08:07 PM
UL to triode mode conversion on cathode bias amp-different cathode resistors needed? bigwill Tubes / Valves 6 30th December 2007 12:37 AM
Copyright ©1999-2013 diyAudio
