ECC82/12AU7 Line Preamp
Soundwise there's difference in bass reproduction, that's why my concern. It's heavier as a first impression, deeper too. That could reveal an early roll off in the original situation but I'm unsure because I'm listening to radio now, not a habit I must confess. Electrolyte has settled within the last days (it's a conventional PS, quite high impedance) and w.r.t. music reproduction I further can't hear difference between both situations (apart from bass). Tonight I'll establish some feedback to see if bass notes remain the same and dig out the old scope and tonegenerator. And furter I must refresh my theory because no calculation I made was right the first time... I even can't find information on the octave (thought it was an interval ranging from a base to a 10-fold frequency)...
In order to calculate the frequency roll off more accurately, you also must consider the output impedance, usually low and mostly neglected, I mean
fo = 1 / [2 π (Rsource+Rload) C]
Input impedance of the following stage will be paralleled with the load, your load actually is low, and when you connect the power amplifier will be lower, and will increase your fo.
Then, the first try would be put a bigger capacitance for C1.
What did you put, 1µF or 4.7µF?
As not exists an amplifier better than its power supply, this is a thing you can improve.
Maybe there are infallible people, that's not my case and I make mistakes all the time; just to give an example, the display size of my old calculator tends to shrink over the years, without new eyeglasses is easier to screw up. 😀
On a side note:
It's called an octave because in the gregorian musical notation system, the one we still use today, the eight whole note (octa = eight, octopus, octagonal, etc.) from the base note is double the frequency.
Musical notes expressed in terms of its frequency, at any upper octave goes as 2^n, that's the reason why even order harmonic distortion is the lesser evil.
However, musical notes are seven, i.e.
Do-Re-Mi-Fa-Sol-La-Si
It's called octave the frequency range between two notes that are separated by a 2:1 ratio
Do-Re-Mi-Fa-Sol-La-Si-Do
In order to calculate the frequency roll off more accurately, you also must consider the output impedance...
Sorry man but this turns into duck shooting :bullseye:
In the above situation both impedances seem in parallel to me.
That would produce a pole of 1/2π x 3K24 x 10^-6 = 49Hz for a 1uF value for C1.
4,7uF (actual size) gives 1/2π x 3K24 x 4,7 x 10^-6 = 10Hz.
2,2uF at 22Hz would be a compromise because of phase shift in the audible region (with better speakers than mine that is).
The abnormal bass reproduction belongs to the radio station (3FM, thanks Giel!) I was tuned to for a while. After two CDs of well known recordings the conclusion is that the CDP gives a familiar reproduction. I could hardly distinct the pre from direct connection via the variable output. It seems the pre delivers a clearer sound stage: sharper imaging of instruments and better distinction of the depth of the field. Although the effect is minimal the illusion is there. Intellectually I can't explain why a 'thermal afterburner' would change something for the better, it will probably come down to just the right amount of harmonics, a little IM or channel bleeding I guess.
Is there a sensible test to perform with signal generator and oscilloscope? I could compare square waves for size and form of course but I don't expect anything to show up...
This circuit is wrong and won't work.
For C1=1µF fo≈10.8 Hz, for C1=4.7µF fo≈2.3 Hz​
Sorry man, but my intention was only to help you, good luck. 😉
Hey come on, he's trying to break the record for longest continues radio show, so he needs some bass to keep himself awake 😀
But seriously, there's so much processing and compression going on with radio that it's impossible to use it as a reference of any kind.
What's wrong?
Johann, I had a quick peek and poke with my scope to obtain some data the empirical way. Remember C1= 4,7uF.
2KHz Input=output at 2,0Vrms or 5,7Vpp
2KHz Input=2,0Vrms Output=9,7Vrms
20KHz Input=2,0Vrms Output=9,6Vrms
20HZ Input=2,0Vrms Output=9,5Vrms
10HZ Input=2,0Vrms Output=9,1Vrms
So, from 20Hz output voltage is dropping.
At 10Hz it's 0,6Vrms down. 20log(25,7/27,4) = 0,5dB
Seems like the pole is lower than 10Hz, as you predicted.
I'm dropping a third of the output voltage here through the devider Zs/Zl.
There's still headroom for some voltage feedback.
Would 5% f.b. be derived from Rfb = 20 Zout ?
Any HF issues to be expected?
This is an inverting amplifier. I don't think you applied the feedback correctly. Notice all the "grass" in the FFT. This is open loop @ 1.16Vrms output @ 1kHz. Since this is driving 1M ohm, THD is very low. I changed the load to 100k and the open loop THD goes up a lot, as expected, and loop feedback brings it down (when the input level is adjusted to match the open loop output level). The "grass" remains unchanged. So, without loop feedback, and putting the volume control after the gain stage, means that you're basically listening to distortion and noise. If that floats your boat, then so be it, but it's not what audio engineers usually strive for in their designs. There's a very good reason that the volume control goes in the front of the preamp, and that's why it's been done that way for decades now.
What's wrong?
With this circuit you don't need to draw the capacitor, it is implicit into impedance, if you decide to draw it, the load must be put after the capacitor, not before.
Mind you that C1 is connected to cathode of the upper triode, then the load would be a "bridge" for the bottom section of the SRPP.
I guess you actually build your original circuit.
Well, at some point I had to hit the nail on the head. 😀
Yes, it's duck shooting for both of us, I was a little upset by that.
Here's the circuit I build:
Of course, you draw a DC circuit and for AC the cap is included.
So, impedance ad up. I'll redo the graphic.
Dirk, would you be so kind to simulate the above circuit.
I didn't get your point for the potmeter at the output.
Baby steps please 😉
The "grass", as you call it, is @ -150dB (at least that's what your simulation program wants you to believe). How is this relevant?
I don't think you understand how your circuit works. Connecting the 1Meg load or not won't make much difference. In your schematic, the lower tube sees about (μ+1)*Rk + rp which is about 6K (ECC88). The upper tube acts simply as an active load. You'll need a much lower load in order for SRPP to work as intended (it's called "shunt regulated" for a reason).
As a side note, closing the feedback loop not only applies the feedback but also lowers the effective load of the circuit significantly (20K at the output) and therefore changing the characteristics.
