Mono push-pull driver PCB - Page 20 - diyAudio
Old 8th January 2013, 01:37 PM   #191
Tubelab_com's Avatar
I'm thinking a PP or even PPP with 18GB5's outputs.....
maybe PPPP! I have 16 13GB5's mounted on perf board which will be used as two sets of 8 in a stereo amp. I intend to explore the upper regions of output power too, but I likely won't get back to it for about 6 weeks.
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 8th January 2013, 04:20 PM   #192
pmillett's Avatar
Originally Posted by pso View Post
Hi, the version with KT88, is finished or still in progress?
I will go back to the KT88 to double-check, but I think this same design will still work fine with KT88's.
As for a "real" build, I am going with parallel 5B/254M's:
5B/254M @ The National Valve Museum
(Just an 807 in a lovely loctal base)
Pete
Old 8th January 2013, 08:25 PM   #193
tomlang is offline tomlang  United States
tomlang's Avatar
What about a PPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPP 13GB5 amp? Here is a pic of 50 in this box, I have another 50 in another box from Rogalski's at 50 cents each in quantities of 100. Says "Made in USA", not sure if these are the "big power" 13GB5's or not.
The nine pin sockets were 35 cents each and the plate caps 30 cents each from Goodcomponent.com. Shipping almost doubled the cost but still a deal. The sockets are #GZC9-2-F and caps #MCV. Caps fit the top nipple but do not shroud the whole thing.
Old 8th January 2013, 09:02 PM   #194
pso is offline pso  Spain
Finally, how will be the B+, 450 or 560V? as indicated in the post 152.
Any update about the boards for the PSU?
Old 9th January 2013, 01:55 PM   #195
wicked1 is offline wicked1  United States
wicked1's Avatar
I got it powered up last night.. Voltages all checked out, got the driver board set up, plugged in the output tubes (3d21wb's, for now). I turned up the bias and they biased properly, (put them at 40 ma) but I had a loud buzz. I turned it off for a quick checkout.. Moved some heater wires, etc. Then turn it back on.. It gets very loud. I look at the meters on bias, and they are pulling about 100ma! I turn the bias all the way down and they are still pulling 40ma! (first power up, w/ the bias all the way down, they don't conduct at all).
So, this morning b4 work I checked the bias voltage, and it's still fine.. (-80v is the max, which is how it was originally).
Now I'm stumped.. What would cause that? My first guess is it's the tubes.. For one, they came out of a huge bin of random unboxed tubes.. And 2nd I've got no plate caps and only have wires wrapped around the anodes.. Would the screen burn up if the plate got disconnected? And could a burned screen cause problems like this?
Old 9th January 2013, 04:15 PM   #196
I had issues with some of my used 3D21WB's. The 5 new ones that I got from ESRC seemed OK but I didn't run them for long. Some of the used ones exhibited bias creep and eventual runaway. Looking back now I believe it was a grid current issue but I don't have an amp set up to play with it right now.
I have a box full of the small plate 3D21B's, but I think they will go to the hamfest next month. I still have way too much stuff in my house.
It is possible, and likely if the screen is connected directly to a power supply. I usually put a resistor in series with the screen. I undersize it (1/2 or 1 watt) during testing but use a 2 watt part for a final design. The resistor will smoke if the plate goes open. The screen will glow white hot before it fries, so it is usually obvious.
Old 9th January 2013, 06:34 PM   #197
wicked1's Avatar
Thanks George. One of the tubes was causing trouble.. Now it's all good
The horrible BUZZZ I had was a bad connection at the input ground.
Bias is still crazy.. As they burn in I have to keep turning it down.. a lot.. and the balance drifts all over the place.. One tube pulls about 1.5x the current for the first few minutes of operation, as it warms up. But.. that's all probably par for the course.. I'll let these burn in for a while.
WooHoo! I suppose I'll start building my regulators and get the other channel built w/ the gu-29 version.
FYI, I didn't pay attention to the amp for 10 min, and the current was up at over 100ma per side for a while.. Over 50watts. The tubes showed no signs of stress.
Old 14th January 2013, 05:01 AM   #198
wicked1's Avatar
PPP 829's
Regulated screen and bias
It is good!
Old 18th January 2013, 01:35 PM   #199
wicked1's Avatar
I've got two versions of this built and have been trying to decide which is the best... It's difficult! They are both similar enough that I can listen to them as a stereo set, and different enough to tell the differences between the no feedback triode version and the pentode (or tetrode) version. Basically everything every other thread has said on the topic is true. I think I like the triode a tiny bit more.. I think the pentode version sounds clearer, crisper.. It's probably technically better. Since it was my plan from the start, I think the 829 version will win.
What surprised me the most is the two versions are much more similar than different.. (I suppose that's how it should be.. we want to hear the music, not the amp)
If anyone is curious, these are my parameters:
7403 (kt88-ish) triode
492 on the plates
-57v on the grids 70ma
243v on the drivers. Drivers are triode too.
829 (807-ish) PPP Pentode (Or should I be saying Tetrode?) Regulated bias and screen supplies
590 on the plates
-28v on the grids 60ma
215v on the screens
305v on the drivers and 150v on the driver screens
UL to driver plate feedback, as well as global feedback. I decreased the global feedback a little after I added the ul to plate feedback. (the all triode amp was louder! and, I do like the sound of less feedback)
And actually, I dont have test equipment to really get in to it, but I did find the amp much more "listenable" after adding the UL to plate feedback.
I suppose I have one question.. Should the 10m45's be hot? As in, turn the amp off, let it discharge for a few minutes, and I still can't touch the heatsink for more than a second. Someone else has my IR thermometer right now, so I can't be more precise than that...
Old 18th January 2013, 03:13 PM   #200
Hi, it appears that the 7403/3D21WB works very well here.
Any particular brand?
Where they are available?
idiot proof mono push pull 6l6gc schematic wanted jasondace2b Tubes / Valves 29 13th October 2011 01:22 AM
Mono 5W-17W Power Amp using EL84 push-pull nbraz Tubes / Valves 30 27th July 2011 11:12 PM
Please Explain difference Mono vs Push Pull vs Single End etc hdlcx2 Tubes / Valves 11 3rd August 2008 02:27 AM
Push-Pull driver stage? alexmoose Tubes / Valves 12 18th September 2006 11:38 PM
Copyright 1999-2017 diyAudio
