diyAudio Sponsor
Old 28th May 2011, 05:50 PM   #1
hidnplayr's Avatar
Default PL84/EL86 push pull
Hi Fellow tube-freaks,
I'd like to present my latest creation, a PL84 push-pull amp.
Perhaps the most interesting thing is that I have tried to use the same output transformers before, with 807's in AB2.
Back then I could not get the wanted results without using gNFB (read: plate to plate feedback - measurements)
Now, I also connected the transformers secondaries to the cathodes of the PL84's.
This has been discussed on different threads here recently, and here: diytube.com :: View topic - Koren Local Hero and Mods
Responce is measured at 1Watt into 8ohms resistive load.
The nasty looking bode-plot is open-loop response.
Full output is more then 20 Watts (again into dummy load)
more pictures: PL84 push pull - My Photo Gallery
Any further suggestions?
Real tubes have top-caps
Old 29th May 2011, 12:18 PM   #2
Tyimo is offline Tyimo  Hungary
Hi!
Nice and interesting amp!
How is it sounding?
What is your ballanced source?
Greets:
Tyimo
Old 29th May 2011, 12:45 PM   #3
hidnplayr's Avatar
Thanks Tyimo,
I dont like to desribe sound. Sorry (I think it depends a lot on the speakers too.)
Lets just say it sounds perfectly good to me.
The plan is to build an RTP3C clone (Vacuum State - High End Hifi Equipment)
So i'll have balanced phono.
I also plan to build a balanced TDA1541a dac with a preamp stage similar to the RIAA stage in the RTP3C.
Later on, I might do the same thing to my reel-to-reel tape deck.
Yes, I plan to go fully balanced but have some work to do!
Old 30th May 2011, 05:23 AM   #4
Hi!
How do you make the bias for the PL84 tubes?
Tyimo
Old 30th May 2011, 11:19 PM   #5
gianis is offline gianis  Greece
Default .
I think ( on the schematic) that the resistors R16 ,and R20 may be connected at the other leads of R4, R5 , otherwise no exists NFB
Old 31st May 2011, 09:40 AM   #6
hidnplayr's Avatar
Gianis: you are right, I made an error while drawing the schematics.
Tyimo: I used two potmeters between 0 and -30V in a way so that I have balance and BIAS.
Here is a corrected and more complete schematic:
Old 31st May 2011, 11:35 AM   #7
Globulator's Avatar
I tried sitting the cathodes in the output of the OPT like that once, it did sound fairly good but later I decided to take the OPT out of the feedback loop completely (I wrapped feedback around the driver+output tube to present the OPT with a low impedance drive, which sounded better).
Your use of the 16ohm and 4 ohms taps seem to give more feedback to one side than the other - 12 ohm output to the top and 4 ohm output to the bottom - is that supposed to be like that or should you connect the earth to the 8 ohm tap?
Old 31st May 2011, 11:41 AM   #8
hidnplayr's Avatar
4ohm + 4ohm on an OPT gives 16 ohms
You need to calculate with voltages, not impedances in this case.
This kind of feedback should give a better damping factor, now it depends if your speakers like that or not.
Newer speakers like it most of the time.
Old 31st May 2011, 12:33 PM   #9
Fenris is offline Fenris  United States
Congratulations, it looks nice. Looks alot like Broskie's Power Buffer that I've been wanting to build: Aikido Cathode Follower & More Triadtron
Listen to the music through the stereo, not the stereo through the music.
Old 31st May 2011, 07:31 PM   #10
smoking-amp's Avatar
Not trying to shoot down your design. But I do see a conflict of sorts between the plate to plate local feedbacks and the CFB on the outputs. The Schade fdbk makes for a low Z load for the driver triodes, and the CFB makes for a large voltage swing requirement besides. I would try putting the Schade fdbk resistors back to the driver cathodes (with some resistance between them), and a CCS load on the driver plates. Then the driver triodes can develop the high voltage drive easily and linearly. May require some more input signal though.
Ohms Law V = I R
"Push-Pull" for push und "Push-Pull" for pull (like Gamnut) - whats the right name? tiefbassuebertr Solid State 68 26th December 2011 07:17 PM
Push-Pull vs Push-Pull-Parallel rsumperl Tubes / Valves 5 13th July 2010 10:10 PM
Yet another Push-Pull croccodillo Solid State 3 2nd October 2009 12:24 PM
modify parallel push-pull EL84 to single push-pull chungtat Tubes / Valves 12 3rd November 2005 11:25 PM
Double push-pull versus single push-pull jraraujo Tubes / Valves 19 19th October 2002 12:23 AM
Page generated in 0.09963 seconds (82.09% PHP - 17.91% MySQL) with 11 queries
