diyAudio Sponsor
Old 25th May 2011, 04:14 PM   #1
tricomp is offline tricomp  Denmark
Default CF/CCS, can it be made simpler?
I'm about to finish a 2C34-PP stereo amp. project.
To pull some usefull Watts from the 2C34 dual-triode I has to be allowed to pull grid-current, about 10mA, hence the CF-drive.
Having so far only put the amp on a scope and a tone-generator and measuring output-power, I have to say I'm pleased with the measured 12W/8-Ohm and 16Watt/4-Ohm. As I don't have a distortion analyzer I used the scope to determine the onset of distortion; not the most precise way, I admit.
When the amp's connected to my stereo and a pair of B&W 685 Speakers (88dB spl/1m, 8 Ohm.) it performs very much as hoped and expected. Rich and controlled bass (NFB applied) clean highs and nice vocals.
Now, my question is if I can safely simplify the CCS-circuit? The Cathode Follower is supplied from a Constant Current Source as per schematic (one channel shown, CF, CCS and output only).
I simply want to reduce the use of 4x6.2Vz and 4x1N4148 in each reference-string for the CCS to one of each. Then to connect each of the four BC549-bases to the 1N4148 Anode. Also could the MJE340 bases be connected to the common point between just one pair of 31K/3K3 resistors? Possibly the current in the reference chain 31K/3K3/1N4148/6.2Vz should be higher if transistors are connected as suggested above?
What you can't see from the schematic is that the -82V supply for the CCS is stabilized and comming from a TL783.
As the amp. is already built and pretty much finished I don't want to rip it apart to experiment needlessly. That's the reason for my question as I know someone here will definately have the right ansver
If anyone's interested I'll of course upload the rest of the schematic and pictures.
rgds and thanks,
/tri-comp
Old 25th May 2011, 05:56 PM   #2
wrenchone's Avatar
Why not just use a DN2540N5 depletion mode fet (Supertex)? THat's the approach I use with all my CF circuits. The current source is then reduced to the fet and two resistors. The output impedance is also pretty high without the need to cascode.
Old 25th May 2011, 06:59 PM   #3
Fenris is offline Fenris  United States
And cascoding with another device is only nominally harder. One extra device, LM317 or LM134 (depending on current) and one resistor. Probably less than half a euro in cost. I cranked out a lifetime supply of PCBs for these (90 PCBs for about $40), so they're very easy to implement.
Listen to the music through the stereo, not the stereo through the music.
Old 25th May 2011, 07:05 PM   #4
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
It is already simple enough, what else do you want?
If to simplify, I would avoid stabilizing of a negative voltage if CCS is stable enough (as drawn on your picture)
The devil is not so terrible as his mathematical model!
Wavebourn: We Create Creativity!
Old 25th May 2011, 07:13 PM   #5
aardvarkash10's Avatar
rgds and thanks,
/tri-comp
Yes please on the complete schematics!
Yes, conservatism thrives on low intelligence and poor information. But the liberals in politics... continue to back off, yielding to the supremacy of the stupid. It's turkeys all the way down. - George Monbiot, guardian.co.uk, 6 Feb 2012
Old 25th May 2011, 07:14 PM   #6
The reason for not using that is I'm not familiar with it ...until now.
LM317 / LM134
Use of these chips with an I-O potential of more than 100V. I don't think so!
The 2C34 g1-to-g1 swing is around 150Vpp
Simple enough
You're right, it isn't all that complicated AND it's already put together and it's working. I was just wondering and possibly I'll make another amp just like this as I already have the laser-cut and bended chassis for it. If I do I'll want to implement any improvements/simplifications, if any.
rgds,
/tri-comp
Old 25th May 2011, 07:27 PM   #7
LM317 / LM134
/tri-comp
http://www.audioxpress.com/magsdirx/...a/jung2779.pdf
Fig. 13C
The LM317 is cascoded using a DN2540N5 or IXCP10M45S, giving it the capability to handle 400+ volts.
Old 25th May 2011, 07:28 PM   #8
The pre-amp/concertina circuit.
The power-supply circuit isn't quite ready for publication as I haven't yet decided if I'm going to run the 6AN8A fil's on DC.
One channel is fully finished and I'm transfering the other pre-amp/concertina from a rats-nest to final point-to-point assembly.
After that and installing the bottom-cover I'll know about hum-level and need for DC-filament.
rgds,
/tri-comp
Old 25th May 2011, 07:31 PM   #9
Fig. 13C
I've been trying to get my hands on IXCP10M45S but it's simply not available from any of my suppliers including RS-Components.
I would REALLY love to work with that!
/tri-comp
Old 25th May 2011, 07:42 PM   #10
That is something I've considered already as I've come across this suggestion in an old (50'ies I think) description of a cathode-driven PP-stage with a pentode-CCS. It was specifically stated that the stability of the negative supply isn't all that important.
I can easily remove the chip and see...
Not tonight, however but more likely over the week-end.
rgds,
/tri-comp
PSRR of CF w/ CCS Sink regal Tubes / Valves 7 30th June 2008 03:13 PM
CCS 10M45 in Cathode of CF Driver danFrank Tubes / Valves 13 5th March 2007 09:41 PM
Experiences with White CF/CCS CF output stage mashaffer Tubes / Valves 50 1st August 2004 03:42 AM
DRD: Simpler path to bliss? rick57 Tubes / Valves 4 10th July 2003 11:24 PM
Simpler Zen Variation 2? jh6you Pass Labs 5 30th August 2002 05:19 AM
Page generated in 0.10972 seconds (81.06% PHP - 18.94% MySQL) with 11 queries
