| diyAudio Sponsor | ||
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
I'm on my way toward building my first tube amp & the most straightforward set-up would be using an autotransformer. Down here I can get a 220-110 at 300W for some $15 USD(60 Pesos) With a core of 5" by 5" by 2 1/2"....
Just how unsafe are these transformers & am I commiting the ultimate sin here by not using a "true" transformer....am I about to be censured? Perhaps I could fuse it three ways to Sunday! Just to throw gas on the fire the grounds here are a hit & miss affair. Household wiring here is shoddy to say the least! __________________________________________________ _____Rick..... |
#2 | |
Gas on the fire is a good enough analogy
I would recommend a proper step-down isolation XFMR. In-fact any time I use an auto transformer it's paired with an oversized isolation XFMER. EDIT>A Fuse or more than one especially is not a panacea for shocking hazard protection.
like four million tons of hydrogen exploding on the sun like the whisper of the termites building castles in the dust Last edited by infinia; 3rd March 2010 at 10:43 PM. |
#3 | |
When I started building tube amps I once used an autotransformer. It gave me many shocks, but I only took it apart when the SOB blew up my expensive DAC. Not recommended.
Good sound comes and goes. |
#4 |
Richard, maybe you can look for a 45/48V secondary and use a voltage doubler
(PSU designer says it can be done)
I know how to walk over grapes |
#5 |
An autotransformer is about the same thing as connecting a wire directly from your circuit to the wall outlet. It has zero isolation. Don't do it. An autotransformer doesn't need quite as large a core (not sure why), so is often cheaper. Is there any part of "Don't do it" that needs additional clarification? Did I mention not to do this? We'd like you to keep posting and the internet connection from six feet under is really bad.
I used to be an audiophool like you but then I took an arrow to the knee. |
#6 |
Lord of the Sparks!
#7 |
Richard,
If you like life, you'll heed the other posters and acquire a proper power trafo. Depending on the B+ draw, either a Triad N-68X (50 VA) or a Triad N-77U (100 VA) will get the job done for you, SAFELY. Both of those isolation trafos have dual primaries, a "115" V. secondary, and they are inexpensive.
Eli D. |
#8 |
The best solution are the Triad xformers (I'm using these), but if You are by no means able to access to imported material, a couple of 220/12V cheap xformers, tied back to back, can do the trick. When feeded trough the step down autoformer ( this one rigorously outboard), You'll get half the socket voltage, and a safe chassis. I've just done this, this morning, to be sure that it works.
#9 | |
Simply put, engineering wise it isn't the done thing and contravenes a raft of IEEE regulations.. In many domestic European locations one often finds there isn't a neutral, but two live phases and earth. Don't blow ones chances. richy |
#10 |
Don't do it, a funeral costs more than an insulation transformer!
Never send a human to do a machine's job. --Agent Smith |
| diyaudio.com - An unsafe site?? | dviswa | Forum Problems | 39 | 2nd October 2009 06:51 PM |
| Toasty autotransformer | Craig405 | Solid State | 21 | 2nd July 2006 10:03 AM |
| Autotransformer for 220v in the UK | Pickledcreeky | Everything Else | 7 | 9th September 2005 05:39 PM |
| Rewinding an autotransformer | Stocker | Parts | 4 | 15th October 2004 04:13 AM |
| Page generated in 0.12609 seconds (81.51% PHP - 18.49% MySQL) with 11 queries |
