Hello,
I just finised my tube entry project the AN6418 Valve (Tube) Preamplifier / Headphone Amp Kit its quite nice and really affordable, for the sound it self I subjetively must say it sound very clear I was missing nothing, therefore im satisfied with the kit. see the image of the amp here http://hex.dan.sweb.cz/minitubeamp/DSC_0837.JPG does anyone here made it as well? For the begining I builded it as it came, but I would lilke to make a few changes so I would like to get the experience from someone else as well. Cheers, Imagios |
#2 |
Looks interesting, how about some information on where to get it, and a link to the seller's website. It's unfamiliar to me and probably a lot of others here.
"Extraordinary claims require extraordinary evidence." - Carl Sagan |
#3 |
This looks like it:
Raytheon JAN6418 Valve (Tube) Preamplifier / Headphone Amp Kit
"The supercomputer is technologically impossible. It would take all of the water that flows over Niagara Falls to cool the heat generated by the number of vacuum tubes required." ~ Professor of Electrical Engineering, New York University |
#4 | |
I came across this the other week. Interesting miniaturized pentodes. I wonder how they sound compared to the common size tubes that we use. |
#6 |
hello,
I bought it on australian Ebay: K272 - STEREO TUBE PREAMPLIFIER - HEADPHONE DRIVER KIT - eBay Tube, Valve Amplifiers, Amplifiers, Audio, Electronics. (end time 18-Dec-09 15:46:10 AEDST) as Oatley Elec. do not ship to Czech Republic. Its easy to build, sound for a amateur nice. But I never lisened to a tube amp therefore please take this with some distance. newer the less I have a headphone amp self made from a kit based on the TDA7053 chip and personaly I like these tubes more than the chip. (but this must say nothing) Im not much knowledgeable in electronics, so I build only kits. But I would for sure change some parts on the board. a potentiometer would be fine... I would be interested to know the THD at the amp... but have no equipment to measure it. But as a introduction to tubes I think its great 1-easy to build, few parts that you can hardly mix up, 2- low voltage (Im not skilled egnouth to play with deadly voltages) 3- good sound (subjetively on common headphones) I will as well conect this as a preamp to mi tripath amp from 41Hz to see what difference it will make. Never the less I was not sorry to instal golden cinch to the amp and a quite expensive jack connector as you might see here http://hex.dan.sweb.cz/minitubeamp/DSC_0836.JPG as well for thouse who might be interrested the "shine" of the petodes: (ISO 200; 30 seconds exposition) http://hex.dan.sweb.cz/minitubeamp/DSC_0845.JPG the biggest problem with the amp is the ring sound comming from vibrations they suggest to use rubber grommets, that I dont have and that are not a par of the delivery(thats a pity) but I dont know how much bether it will become. I can not imagine to use this as a travel amp in a bus,car, train as I think it would ring... but to have it on stable place makes it a quite nice travel amp, desk at work, library, waiting room, what ever ... One common 9V battery can power the amp for good 10 hours without loose of "power" but I think to buy a Li-ion batery and make it a travel amp with rechargable embeded batery. Quite easyer than to exhange bateries. |
#7 |
Magneto the Gravity Man
Anyone know about Oakley's K261 preamp Kit.
It seems to use a smal smps to supply the 30v HT. Oatley Electronics
If it ain't broke, break it !! Then fix it again. It's called DIY ! |
#8 |
I have one too and decided to upgrade some of the mediocre quality parts since I want to use it as a preamp with my mini Aleph in the living room.
Here's my BOM Resistors: all resistors 1% metalfim types Caps: C1,C2,C4,C5 MKP1837 0.1uF C7,C8 Elna Silmic ARS 220uF 25v Trimpots: Piher 1M Opamp: OPA2134PA I replaced the opamp socket with a better one and connected a decoupling cap (a "104") to the supply pins on the reverse side of the PCB. For the tubes I came up with a diy socket. I butchered a large IC socket to make two 5-in-line sockets for the tubes. Tube (re)placement now is quick & easy. The Elna's are 12.5mm diameter and they just barely fit. I plan on using MKP1837 0.01uF bypass caps on the Elna's once I have them. As for tube dampers I use a short piece (~32mm) of clear silicon tubing with the side cut open. Last edited by Beftus; 13th January 2010 at 09:58 PM. |
#9 |
Imagios, take a look at a piece of your photo. The stray strands are a shortcircuit waiting to happen... Cut them!
#10 |
All -- Good info here --
Raytheon JAN6418 Valve (Tube) Preamplifier / Headphone Amp Kit There also are several great threads on the forum for this site. |
| Can 'ARTA' measure tube electronics? | Cousin Billy | Multi-Way | 5 | 6th December 2008 01:35 PM |
| preamplifier and sure electronics | kankara | Class D | 1 | 13th July 2008 11:58 AM |
| S-5 Electronics Tube Amp Kit | dru85 | Tubes / Valves | 5 | 10th June 2006 04:16 PM |
| S5 Electronics 139 $ tube amp | Gubby | Tubes / Valves | 4 | 19th November 2004 04:28 PM |
