Yaqin mc10L - Page 23 - diyAudio
Old 22nd January 2013, 08:35 PM   #221
Hi_Q is offline Hi_Q  England
Hi_Q's Avatar
You only need to pull V2 if it is the left channel you have problems with. If the hum goes the problem is probably in the pre-amp. If it is still there then maybe you have a problem in the output stage or the coupling.
Old 22nd January 2013, 08:53 PM   #222
Ok, the hum is still there, so what next Les ?
Old 22nd January 2013, 09:50 PM   #223
Hi_Q's Avatar
What are the bias voltages on the two left channel EL34's? They should be more or less the same at around 0.35V as measured across the 10 Ohm bias measuring points.
Old 23rd January 2013, 07:20 PM   #224
Ohhh... so that's all it was lol. I didn't touch the bias... Yep on that side I got readings of 0.08 and 0.67. So now the fun of putting the new caps back in
Thanks Les
Old 26th January 2013, 12:36 AM   #225
Does anyone know the value of the potentiometer ?
I want to replace it with a motorised one. Hificollective offer 20K or 50K alps blue dual gang. But other values are available from elsewhere.
Old 26th January 2013, 01:16 AM   #226
Pot is 20k. You should be able to find the schematic with a Google search. If you can't find it send me a PM.
You may find this interesting:
http://homepage.ntlworld.com/lez/YAQ...IN%20MC10L.pdf
Old 26th January 2013, 01:23 AM   #227
Thanks, 20k
I have just realised that hificollective are asking 100 for the pot + receiver.....
Old 30th January 2013, 06:56 PM   #228
Time for a little rewire of the signal cables. Straight forward enough, however the ones leaving the preamp board to power stages are 3 core. Can someone explain this and also identify the connector types please so I can get more of them
Old 2nd February 2013, 01:30 PM   #229
Does anyone have a schematic for the amp please ?
Old 2nd February 2013, 02:04 PM   #230
Koifarm is offline Koifarm  Netherlands
Koifarm's Avatar
At your service.
Usefull link: http://www.cathedralspeakers.com/yaqin
Help and your input on YAQIN MC10L EL34 kalinga Tubes / Valves 6 27th January 2011 09:39 PM
Yaqin MC10L and KT88 megalodementia Tubes / Valves 21 15th January 2011 02:51 PM
MC10L is good or not iao Tubes / Valves 5 14th August 2010 12:22 PM
Yaqin mc10l "popping" Reg Stir Tubes / Valves 5 5th August 2008 05:43 PM
Yaqin MC-10L cruzrman Tubes / Valves 0 23rd July 2008 03:37 AM
Copyright 1999-2017 diyAudio
