Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Tubes / Valves All about our sweet vacuum tubes :) Threads about Musical Instrument Amps of all kinds should be in the Instruments & Amps forum |
#2441 |
diyAudio Chief Moderator
#2442 |
K thanks Salas. Once built I might give it a go. If the results are good I'll report back.
Nick |
#2443 |
Salas,
I've built a resistor loaded version of your 6V6 preamp with my B+ of only 300V, so I used 7.5K anode resistor as recommended by you with very good result. I have a pair of Magnequest plate chokes, BCP-15 which is 50H/40ma/575ohm. I'd like to know if theirs inductance is enough for adequate bass response and in the case they can be used then how is the new B+ should be. |
#2444 |
Congratulations for your build. Let us know more about the system you added it in. Build photos are welcome. About the plate chokes, yes they are a bit on the low Henry side...
It will roughly show -3dB at 10 Hz and 40deg phase shift there theoretically as a combination. Not great for zero LF phase shift, but it will play bass. Up to you deciding a test if its handy so to see how you like them. It will play couple of dB louder also, so normalize that when comparing. You will be needing 180V B+ for them. |
#2445 |
Salas,
Thanks for your response, The system I'm using now consist of: Source-Mac mini =>DAC-TEAC UD501 => 6V6 preamp => Fetzilla Power amp =>ProAC 2.5 clone With 6V6 preamp, the system has become very dynamic and the frequency response is good from bass to treble, very good for classical music which I listen most of the time. I'm sorry no picture at the moment. I'll try choke load and compare with resistor load later. |
#2446 |
OK good luck with the experiment, and keep us posted.
#2447 |
Hi Salas,
I just wanted to verify if you are now using a 2.2uf output capacitors. If. Im not mistaken you have mentioned in one of your posts but cannot remember where. Im ordering parts for the build, and want to get the right one. Thanks |
#2448 |
Hi Salas,
One more question, sorry for the inconvenience. I also have an ldr based volume control which i will be usinginstead of the 100k pot. Do i still need to wire a 100k resistor from the grid to the ground of the 6v6? Also is it very important to retain the 1k resistor at the grid of the 6v6? In my last build i took it out as it sounded a little better without it. Thanks |
#2449 |
not Salas, but it is a good practice to install a 1meg grid bias resistor(not absolutely required) and a 1 ik carbon com resistor closest to the grid, pin 5...
the choice of output capacitor size is dictated by the input impedance of the amp that your preamp will drive...
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B |
#2450 |
Thread | Thread Starter | Forum | Replies | Last Post |
Help me design my DAC/Line Preamp. | kuroguy | Tubes / Valves | 7 | 2nd April 2009 08:31 PM |
preamp line ctt | richwalters | Tubes / Valves | 1 | 7th March 2008 04:34 PM |
Preamp for Line In and Mic | blur | Instruments and Amps | 1 | 4th January 2007 04:02 PM |
Line stage preamp, based on SY's "Heretical Unity gain line stage" | Danko | Tubes / Valves | 23 | 18th July 2005 04:07 AM |
Line preamp for 2A3 amp | Petman | Tubes / Valves | 0 | 24th May 2002 03:11 PM |
New To Site? | Need Help? |
