Go Back   Home > Forums > Commercial Sector > Vendor Forums > Tubelab
Tubelab Discussion and support of Tubelab products, prototypes and experiments
Old 13th July 2009, 05:25 AM   #121
Hello,
Spoke too soon. Now I developed distortion on the right channel arrrgghh!
Can someone post a schematic on their grounding scheme please? I think the schematic on the website is lacking. Thanks and Godspeed.
John Revilla
Old 5th February 2011, 08:04 PM   #122
rknize is online now rknize  United States
rknize's Avatar
Send a message via AIM to rknize Send a message via Yahoo to rknize
Default Smells like toast
I had just popped-in my Tung-Sol reissue 6550s. It was playing for a few minutes when I noticed that the tube distress indicator was lit (red plates). One of the tubes was running away. When I approached the amp, it smelled like burnt toast. I took it apart only to find one burnt cathode resistor. It's in parallel with a 5W 680 ohm resistor. I replaced it, but forgot which tube was doing it, so I ran it with the 340 ohm bias setting, which has 2 680 5W resistors in parallel. The bad tube did the same thing, slowly rose in current and started to approach the 63V limit of the cap. The cap tested good and looked fine, but now I'm thinking I should have replaced it. Oh well, we'll see what happens.
I put one of the other 6550s in and it works fine. Tube has some kind of internal short or alignment issue I guess. It worked fine at various points in the past and does play music, but likes it hot.
File Type: jpg tubelab-simplese-cathode-resistor-toast.jpg (225.2 KB, 218 views)
Old 14th February 2011, 04:22 AM   #123
rknize's Avatar
Finally got the manual exposure on our little point-and-shoot to do what I want. Love these SEDs.
Tubelab Simple P-P booangler Tubelab 558 23rd April 2012 12:10 AM
Electrolyticless Tubelab Simple SE nic6paul Tubelab 21 10th April 2010 08:00 PM
Second Tubelab Simple SE board done budmaestro Tubes / Valves 0 24th July 2008 12:18 AM
Tubelab Simple SE & Edcor waam68 Tubes / Valves 2 6th March 2008 12:15 PM
New SET: JE labs simple 45 or tubelab SE? cwujek Tubes / Valves 14 27th November 2007 04:15 AM
Page generated in 0.07869 seconds (75.26% PHP - 24.74% MySQL) with 11 queries
