The diyAudio Store A forum for discussing anything about the products available in The diyAudio Store.
Power Supply Soft Start Board (V2)
Old 13th March 2014, 06:09 PM   #151
SRMcGee is offline SRMcGee  United States
SRMcGee's Avatar
120 VAC . . . 1uF . . . 1440R
Good decisions are derived from experience; experience is derived from bad decisions.
also, "Love + Time - Distance = Hate" (Louis C.K., 2017)
Old 13th March 2014, 11:31 PM   #152
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
so now we have values that work.....
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 10th August 2014, 12:37 PM   #153
JRC4558D is offline JRC4558D  England
Hi everybody here.
I am building a Regulated PSU for a modular synth, it is a big one.
I am using a 300VA toroid trafo, 230V primay, 15-0 & 15-0 secondaries.
My filters are two 10000uF caps, using two 25amp bridges and two LM338 regulators.
The idea is getting +15 and -15 volts 5 Amps.
Should I need a soft start? I believe that I should, but after reading the whole 16 pages of the forum still I am not sure if this soft start is suitable for Regulated PSUs.
Any advise will be apreciated.
Thanks a lot in advance.
Old 10th August 2014, 01:12 PM   #154
The 300VA should run with a T1A, or T1.25A, mains fuse.
The 300VA will probably not start on that size of fuse, so you will need to fit a soft start.
regards Andrew T.
Old 10th August 2014, 03:36 PM   #155
Thanks a lot AndrewT for your really fast answer.
I was reading carefully all the posts and as far as I can understand I should use C9 1uf/400v R15 to R18 1K5 5W. Right?
R= 230x230/5/30 = 352.67 comercial value: 360R
360R x 4:1440 ohms commercial value 1K5
Is that right or I am doing something wrong here?
Thanks a lot!
Guillermo
Old 11th August 2014, 08:17 AM   #156
This is a direct to mains powered project.
If I discuss details of how to build this, or how to modify, I risk being sin binned for breaking Forum Rules.
What I have answered
is a general question that is not specifically direct to Mains.
regards Andrew T.
Old 11th August 2014, 09:34 AM   #157
Many thanks Andrew, I got it.
Don't worry I'll find the way.
cheers.
Old 11th August 2014, 11:54 AM   #158
TonyTecson's Avatar
Originally Posted by JRC4558D View Post
Hi everybody here.
get a mains switch good for at least 10 amps, i do this all the time...no need for soft start...
Old 11th August 2014, 04:08 PM   #159
Hi AJT, thanks a lot for your answer.
I have another PSU (51X Group DIY Lunchbox) and I did that (big switch), the Toroidal Transformer there is 250VA and I had to place a 3.1Amp fuse because the fuse was blowing everytime I turned it on.
I think for this new one which has a 300VA toroid I should use a 4 Amp fuse t avoid it blowing, then reading the all the posts I think a 4 Amp fuse will be almost useless. Am I wrong? That's why I ask for a suitable soft start.
Unfortunately I haven't got enough knowledge to be really sure about it and the consequence of not fiting one.
Cheers.
Old 11th August 2014, 04:13 PM   #160
Mooly's Avatar
I'd imagine a 4A time delay fuse would be fine for 300va. It must be a delay type though (slow blow) which will be marked something like 4AT or T4. I've used T6.3 fuses with no problem on a 650va toroid.
Power Supply Soft Start Board (V2)Hide this!Advertise here!
Soft Start PC Board organics1 The diyAudio Store 2 29th March 2013 04:18 AM
soft start power supply for dynaco st-70 yero Tubes / Valves 9 8th July 2011 08:43 PM
Adcom 565 DED!!! Soft Start Board? dracoskeeper Solid State 2 6th June 2010 04:29 PM
Blown 20watt 4.7uf on soft start board ben62670 Solid State 4 26th June 2007 05:29 AM
Commercial Soft Start board wytco0 Parts 0 5th August 2005 04:26 PM
Copyright ©1999-2017 diyAudio
