| Swap Meet Sell your stuff here, who knows, some other fanatic might be interested! |
Hello
I would like to ask for some help . I used many different value Silmic II capacitors but all had brown sleeve in gold letters . I just purchased from Ebay 100uF 63V Silmic II and it has black sleeve with gold lettering . ![]() Unfortunately I didn't found at Parts Connexion 63V 100uF Silmic II . Did someone ever purchased Silmic II in black sleeve??? Please let me know . If I mount them I can recognise the sound but after I'm unable to return them . Thank you very much . Greetings |
#2 |
the writing doesn't look right to me at all, but what do I know.
#3 |
#4 |
Hello
The brown is orig that sure ! The writing look the same on both. I only never met Silmic in black sleeve . Greets |
#5 |
The original Silmic's where brown with gold lettering, RHOS compliant units changed to white lettering, the same for Silmic II's. I have never seen black silmics only tonerex.
#6 |
Hello
You right , these is fake Silmic . I just look up at the Silmic side ! To return it with tracking number it cost me almost as much how much I paid for the 4PC Silmic ! ![]() All I can do I will leave negative to the guy and warn the people not to buy these fake Silmic II capacitors . ![]() Here is what I found about the Silmic II on their site . Elna Silmic (ROS Series) & Silmic II (RFS Series) Electrolytic Capacitors High-grade Silk fiber capacitors for Audio. The SILMIC series are Elna's highest grade audio capacitors that exhibit superior acoustic characteristics. An entirely new type of electrolytic separating paper is used, containing silk fibers. The extreme softness of silk can mitigate vibrational energy (generated by the electrodes, by external vibrations and by electromagnetic fields). Due to it's new electrolytic and foil design the signal propagation speed has increased (the ESR is reduced) and a more powerful, yet-mellow, sound is possible than before. When these capacitors were subjected to aural evaluations, the high range peak and mid range roughness were reduced substantially. Also, the low range richness and power were increased in the obtained high-quality sound. Capacitance Values: 0.47uF - 6800uF Voltage Values: 6.3Vdc - 100Vdc Technical specifications: temperature range: -40 to +85 degrees C tolerance at 20 degree C, 120Hz: 20% endurance at 85 degree C: 1000hrs oxygen free copper leads Red gloss sleeve with gold markings (non-ROHS) brown matt sleeve with silver markings (ROHS) Last edited by gaborbela; 23rd April 2010 at 07:11 PM. |
#7 | |
![]() You could let us know who to avoid though, no point in other people making the same error
"Never let your morals prevent you from doing what is right!" Salvor Hardin |
#8 |
You have not done your due diligence to determine if these are fake. Contact ELNA and get confirmation.
#9 |
Magneto the Gravity Man
If it ain't broke, break it !! Then fix it again. It's called DIY ! |
#10 | |
Note that Elna lists many RoHS types as having either black or brown sleeves and white lettering. I was not able to find the specifics on the Silmic in a quick search, but yours might be genuine. (I buy all of mine from Elna approved distributors.)
www.kta-hifi.net |
| Real or fake Elna Silmic II capacitors | Groundloops | Parts | 9 | 4th March 2009 04:42 PM |
| Elna Silmic II for DC Filter | Stefanoo | Parts | 4 | 24th November 2008 10:47 AM |
| Need some Elna Silmic II | Stefanoo | Parts | 6 | 18th November 2008 09:43 AM |
| Elna Silmics or Silmic II | coffin | Parts | 21 | 11th November 2005 08:47 AM |
| Page generated in 0.10961 seconds (78.78% PHP - 21.22% MySQL) with 11 queries |
