ScottG, check out this B&C 12TBX100 design
Old 12th October 2006, 05:29 PM   #51
alexcd is offline alexcd  United States
alexcd's Avatar
Send a message via AIM to alexcd Send a message via Yahoo to alexcd
Will a slot port work as well if I aimed it down? I am thinking of coming straight up the back of the box and along the top. So, one 90* bend but I would use PVC pipe to smooth the corners. Is that okay? I can reduce the height of the enclosure significantly this way which is what my buddy wants.
Old 12th October 2006, 05:34 PM   #52
alexcd's Avatar
Oh yeah, I forgot to mention that he also shot down the sand idea, sorry. I'll try it myself some day but this is just going to be a well braced enclosure.
Old 12th October 2006, 09:56 PM   #53
ScottG is offline ScottG  United States
I've seen (somewhere) that something closer to a slot was actually better.
IMO its all down to how low friction the sidewalls of the port are and that IF there is any bend, that the bend is "gradual" rather than "abrupt". A "pure" 90 degree bend is horrible. A 90 degree bend that happens over a gradual arc should be OK. Remember, the port represents a "slug" of air mass that is in effect a driver diaphram without a motor (the mechanical compliance is essentially the structure of the pipe and any internal resistance it has). Effectivly that "slug" needs to be able to freely "pump" back and forth.
Bummer about the "sand".. sounds like another compromised design.
perspective is everything
ScottG, check out this B&C 12TBX100 designHide this!Advertise here!
PSU Design Check Please ANDYLASER Power Supplies 14 15th July 2010 12:42 PM
New Here. Will you check me design? SightSeeker1 Subwoofers 19 13th April 2006 04:59 PM
My new design... double check please? Feandil Multi-Way 0 26th April 2005 04:46 AM
Copyright ©1999-2017 diyAudio
