I moved into a condo a few years ago and I've been subwooferless the whole time. I came across the Totem Dreamcatcher one day.
http://www.totemacoustic.com/english...eamcatcher.htm I had a listen to it and decided it was perfect. It's sounds great, is very small (w 7.75 x d 10.75 x h 10.25”) and perfect for my tiny living room. Also as a major bonus, it has very high WAF. Then I asked about the price. $850 Canadian. I decided it was time to get back into DIY. My current 5.1 (minus the .1) is all DIY MTM's that I built about 5-6 years ago. I'm looking at building something based on the TB W8-740C. I find the occasional mention of it, but I can't find any plans or pictures of completed projects. If someone can point me in the right direction for success stories with this driver or something similar, that would be great. I want to keep the box as small as possible. Apparently Audioxpress had an issue with a design for this driver. I can't find it listed in the back issues on their site. Anyone know what month that was? |
#2 |
That sub looks like it won't add anything your mains can't do already, assuming some typical 6.5" midbass drivers in them.
There are a gazillion sub examples out there, but if you have strict WAF requirements, they selection is smaller. In that case it's not difficult to design from scratch. Just get WinISD pro and start modelling drivers ... A few WAF ideas: * IB subwoofer if you own your own place * a conventional sub with a 12" driver in something made to look like conventional furniture ie. a coffee table, or a chest of draws that is really a sub * put it in a corner and make it a slim rectangle - ie 13" x 8" foot print and it can be tall to make up the required volume
AUDIO BLOG | Bass integration guide My work: www.redspade.com.au web design studio |
#3 |
You could try a single Adire Audio Extremis...
DIYaudio for President ! |
#4 |
Thanks for all the suggestions. I've done the "coffee table/foot stool subwoofer" before but I had trouble hiding the wires good enough.
It won't take much of a subwoofer to add to my system. My current mains and center have just 4" mids. http://coquet.info/ht/tower1.jpg http://coquet.info/ht/tower2.jpg The Adire Extremis looks very interesting: "Our favorite application: 21 liters, tuned to 33 Hz with a 2" flared port of 8" length. Clean and flat anechoic response to 35 Hz, and in-room extension to the low 20s." Time to start playing with WinISD. |
#5 | |
Previously: Kuei Yang Wang
Konnichiwa,
http://www.apexjr.com/SuperSub.htm http://www.apexjr.com/ApexJunior.htm You do need to equalise the SuperSub when used in a small sealed enclosure, the Apexjr Plate Amp is easily changed for that. The Supersub & Amp caertainly exceed the REL Quake Sub in performance and build quality is very high. The Subamp includes a cover, so no seperate airtight section is needed for the Ampp. Sayonara |
#6 |
A little OT but are those Whamodynes you built? And if so, did you ever build the matching BP subs?
amt |
#7 | |
I'm missing something I guess.
#8 | ||
Konnichiwa,
True, the extremis is better on paper (never heard it) but is it worth 2 & 1/2 times the price, in the application? At any extent, my suggestion overall costs $ 130 US plus shipping and wood and works well together, making for a cheap and capable small sub.... What is your problem with that? Sayonara |
#9 |
DAYTON DC200-8 8" CLASSIC WOOFER
Same excursion for 20$, way lower Fs. DAYTON SD215-8-8 8" SHIELDED DVC SUBWOOFER More excursion for 23$, way lower Fs. DAYTON RS225S-8 8" REFERENCE SERIES SHIELDED WOOFER Even more excursion for 43$, way lower Fs. DAYTON 8" QUATRO SERIES SUBWOOFER 4 OHM Two times the excursion for 49$, lower Fs. Sorry, I was talking about what the driver look on paper (specs), not "visual" look, I don't care about that at all. It's affordable, you're right, but a subwoofer with less than 5 mm Xmax scares the hell out of me. The ApexJr amplifier is a nice solution, I'd pair it with another woofer that's it. 140$ + shipping with the Dayton Quattro, better I guess.
#10 | |
The Apex Junior sub looks interesting too and it's only $40 US. |
| My XXLS Subwoofer building thread... | harrisni | Subwoofers | 9 | 28th October 2007 08:21 PM |
| Small Narrow Subwoofer | jcmjrt | Subwoofers | 7 | 21st October 2007 04:27 PM |
| Small subwoofer questions | bigparsnip | Subwoofers | 39 | 28th April 2004 07:25 AM |
| Subwoofer on the small | jj | Subwoofers | 1 | 24th February 2004 09:20 AM |
| Page generated in 0.17495 seconds (69.07% PHP - 30.93% MySQL) with 11 queries |
