Analog Servo Sub Analog Servo Sub - Page 2 - diyAudio
Analog Servo Sub
Analog Servo Sub
Old 29th July 2013, 09:52 PM   #11
bentoronto is offline bentoronto  Canada
Analog Servo Sub
Originally Posted by bolserst View Post
snip
The only other suggested I would have is to try a larger accelerometer coupling capacitor(C2) to gain a bit more phase margin at your low frequency oscillation region.
Keep up the good work!
snip
Yup - we all love your good work! And you are lucky to have an informed person like Bolserst critique your posts.
Or you might consider a smaller capacitor (or other intervention) to cut down the loop gain at that point, depending on the Nyquist status of phase and gain. Better to end up a good stable system than to shoot for the moon and miss it. Quite a balancing act where the ups-and-downs are so dramatic.
After all these years of having speakers not in a feedback loop, any modest improvement is a big step forward. Unless we are talking about electrostatics, ahem, ahem, getting speaker distortion comparable to amp distortion is a hopeless effort. But then current amp distortion is way below perceptible levels while speaker distortion is not.
Ben
HiFi aspirations since 1957. Currently working on motional feedback again... the final frontier in audio
Old 29th July 2013, 10:55 PM   #12
Armand is offline Armand  Norway
Thank you all for your response. I am going to answer your questions and do your suggested measurements and post my findings. But it will have to wait a few days. Wife and two kids....
Armand
Old 30th July 2013, 06:44 AM   #13
superR is offline superR  Netherlands
Thanks,
Like Bolserst I am interested in the actual sub 20Hz behaviour. Physics don't agree with the phase and magnitude The overlay looks more like the dynamics I would expect.
Old 31st July 2013, 09:19 AM   #14
Analog Servo Sub
"Loop gain" should really be something that R8-R9 adjusts (replacing the two resistors with a pot). Thus the pot would control the amount of input from the accelerometer into the amp, instead of being fixed. The term refers to the amount of control exercised by the accelerometer feedback loop, not the gain of the whole amp.
In practice, you have the input level control pot (input_gain, 10k). But more logical to control the feedback loop rather than the input level (or both).
Do I have that right?
Ben
Old 31st July 2013, 09:28 AM   #15
Originally Posted by superR View Post
Thanks,
Wait a minute! I thought you were using a current feedback amplifier instead of a voltage feedback amp. Let's think this over
Old 31st July 2013, 02:09 PM   #16
bolserst is offline bolserst  United States
bolserst's Avatar
Loop Gain is the gain around the feedback loop path. Generally to measure it you break the loop at the red X in the figure and inject signal at "Input" and measure resulting "Output". Loop Gain in dB would then be 20*log(Output/Input). Since it is the total gain around the loop that matters, you can adjust the gain of opamp U2 with R8-R9 as you suggest. But it is just as valid to set the loop gain by adjusting the gain of opamps U3A, U3B, or the poweramp LM3886 for the matter. All that matters is the total gain. In practice it is best to divide the gain between the stages in a manner that maximizes headroom and S/N ratio.
The only stage whose gain should not be considered is that of the input buffer U1, since it is not inside of the the feedback loop.
That measurement was "open loop", so no motional feedback was used in that test case.
Old 31st July 2013, 07:48 PM   #17
Analog Servo Sub
snip Since it is the total gain around the loop that matters, you can adjust the gain of opamp U2 with R8-R9 as you suggest. But it is just as valid to set the loop gain by adjusting the gain of opamps U3A, U3B, or the poweramp LM3886 for the matter. All that matters is the total gain. In practice it is best to divide the gain between the stages in a manner that maximizes headroom and S/N ratio.
We're getting lost in terminology. I think we are looking for something called "the feedback fraction" or something like that. Sometimes (but not here), the gain of the sub-assembly represents what we are interested in and we look at the difference between with-accelerometer-feedback and without-accelerometer-feedback.
You want to know, "how much negative feedback are you using from the accelerometer?" And the next steps are to adjust the amount of feedback and phase, where troublesome. So working on R8-9 makes sense - even though in a purely disputative sense you could argue about it.
Ben
Old 31st July 2013, 08:43 PM   #18
bolserst's Avatar
In feedback or control analysis Loop gain = β AOL (feedback fraction x open loop gain)
The feedback fraction(β) is a useful term to use in amplifier design as it is the fraction of the voltage output that is fed back to the input. But the term is troublesome to use in MF woofer design where the "output" is SPL and the feedback signal is "voltage". Talking in terms of loop gain tends to make more sense.
I wasn't trying to be argumentative. Rather, I was attempting to point out that doubling(or halving) the gain of U2 with R8-R9 will change the loop gain, phase, SPL, distortion etc exactly the same as if U3A or U3B gain had been doubled(or halved) instead.
Old 1st August 2013, 11:13 AM   #19
I was talking about the amplifier. I thought he used a current feedback amplifier, but instead he used a voltage feedback amp....
Old 3rd August 2013, 08:49 PM   #20
Robbintip is offline Robbintip  Netherlands
Please take a look at this: MFBfreaks.com • Toon onderwerp - 537 prototype
Analog Servo SubHide this!Advertise here!
To servo or not to Servo.. ReSiStAnCe Chip Amps 16 23rd July 2014 12:46 PM
Analog solution for E-MU 1212m without its analog board ceteras Digital Line Level 0 14th July 2013 10:14 AM
For sale: Ultra Analog DAC, Ultra Analog AES20, HDCD filter mihow2007 Swap Meet 2 30th November 2012 02:05 AM
Possible to convert servo amp to non-servo? mfaughn Subwoofers 8 19th September 2011 06:46 PM
HDMI to analog, or multiple analog channel mixer TAYLOR1337 Digital Source 1 12th September 2011 09:17 PM
Copyright ©1999-2017 diyAudio
