I have a total of 76w x 80d x 16h (56cuft) that I have available. Which seems to be a good amount of space for 4-15's in a t-line configuration or a tapped horn.
Suggestions on box configuration and or subs would be greatly appreciated. I have not bought any drivers or amplifiers yet. I will be using pro amplifiers. I do like the bass loud but sound quality is my #1 goal. Thanks in advance for the advice! |
#2 |
Hi 2MuchRiceMakesMeSick,
The 16" dimension will make a TH more difficult, you need about 2" more than the basket O.D.. You also will have to define your parameter: cost, output SPL, portability... For starters take a look at this thread: http://www.avsforum.com/avs-vb/showthread.php?t=1189404, then at this one: http://www.diyaudio.com/forums/subwo...n-2x12-th.html Regards,
Oliver |
#3 |
Thanks for the reply.
Cost: Would like to keep the subs less then $750 usd each. So no more then 3k for the subs. Output SPL: I think im using enough drivers that it will be plenty loud. Quality is my #1 goal. Portability: Its a permanent install. |
#4 |
How about a design similar to the DTS-10, but with the TC Sounds Epic 12 (for sale at Parts Express): Regards,
Oliver |
#5 |
I may be able to squeeze a few more inches. What about two of these drivers in a tline configuration?
TC Sounds LMS Ultra 5400 18" DVC Subwoofer 293-666 I am still reading on the DTS-10 box |
#6 |
To confirm- the available front baffle space is 76" x 16"?
#7 |
Yes I can use 80x16 as the front baffle or 76x16. I was thinking about 3 18's (TC Sounds LMS Ultra 5400) as they would fit very nicely and seem to have the parameters you look for when designing a t-line.
#8 |
Because of the price point I would prefer the TC Sounds Epic 12. If you're thinking in the direction of a transmission line: since the advent of Hornresp and AkAbak I would not recommend the simple TL format any more (OK go ahead just shoot me :-)), but I would go with bjorno's favorite the T-TQWT instead. Two of the 12s in a T-TQWT would be as loud as one of the 18s for a given power within the 12s Xmax limitation, and with two drivers you can reverse mount one to provide you with additional distortion cancellation. I'll attach a quick price v. displacement comparison: Regards,
Oliver |
#9 |
Hi again,
I took a real rough run at it, and four T-TQWT boxes, each with two TC Sounds Epic 12", would fit into that space just nicely. They would be single fold, quite easy to build. 76" x 16" front face for the four. Regards,
Oliver |
#10 |
Ok I will look into tapped horns.
Is there any way, if I increase the height to 18, that I can fit two TC Sounds LMS Ultra 5400 18" in that space in a TH configuration? The reviews I have read on this subwoofer are VERY impressive. |
| Can I do a Jordan Jx92S in a .75 cuft cabinet? | stephenmarklay | Full Range | 9 | 21st December 2009 08:14 PM |
| Subwoofer box for a Xenon x10d2. Need Suggestions. | Ornlu | Subwoofers | 3 | 23rd May 2005 07:32 AM |
| Please help creating subwoofer enclosure | Lach O'Sullivan | Subwoofers | 13 | 8th September 2003 06:20 AM |
| Page generated in 0.10888 seconds (79.84% PHP - 20.16% MySQL) with 11 queries |
