Will 2lab12 in a tapped horn move more air and out do a 18TBX100 in a tapped horn from 35hz to 150hz
#2 |
Hi kornnylike,
Take a look at Art's (weltersys) Keystone sub thread: Keystone Sub Using 18,15,&12 Inch Speakers Regards,
Oliver |
#3 | |
#4 |
A single 18TBX100 has more displacement.
As for what gets louder, well, depends on the setup.
Building a 2.1 system out of a 3/4"x4'x8' sheet |
#5 |
#6 |
Guys thanks for the above info and links.
This is what i am after efficient and going low with 4 box per side Most of the design using the lab12 or flh. if 2lab12 in a flh is more efficient and go lower than 2lab12 in a tapped horn. i would use a pair of lab12 in the bass horn Epa design for me.Bass horn would need modification to fit the lab12. ![]() The 18tbx100 is known to be used in tapped horn, if the 18tbx is more efficient and go lower in a tapped horn than a 2lab12 in a TH or FLH. I would use the TBX in one of Epa design. epa designs.jpg speaker price 2 lab12 $ 322.00 18tbx $294.00 Which way to go Last edited by kornnylike; 27th November 2011 at 01:19 PM. |
#7 | |
not sure if it works with the tbx,have 2 sim it i can try to convert the korrny box in a double 12 horn but it wil be bigger i gues
one good thing about music ,when it hit you feel no pain. so hit me with music. |
#8 |
[QUOTE=epa;
not sure if it works with the tbx,have 2 sim it i can try to convert the korrny box in a double 12 horn but it wil be bigger i gues[/QUOTE] Thanks epa i will go with the one that is more efficient and go low Last edited by kornnylike; 27th November 2011 at 02:08 PM. |
#9 |
Hi kornnylike,
Going back to wood1y's thread: 15" tapped horn with RCF I found a nicely documented tapped horn by Xoc1 that actually seems to work fine with the factory T/S parameters of the B&C 18TBX100. Hornresp calculates the V_net to be 454 litres, so this might be the volume range you could use to compare other designs to. Regards,
Oliver Last edited by tb46; 27th November 2011 at 04:17 PM. |
#10 | |
Good find Oliver thanks |
| Page generated in 0.40620 seconds (24.26% PHP - 75.74% MySQL) with 10 queries |
