I am curious to know whether single 18" double bass reflex enclosures would be any good for outdoor djing and p.a uses if possible.I know they may turn out to be very large but just curious and which software can best model these with drivers and port front-facing.
#2 | |
If you for example take BMS 18N860 and use it in a 250 net litre BR cabinet and tune it to 23Hz, it could produce some 117dB/1m/1500W outdoor, baffle step diffraction loss taken into account. It's capacity extends relatively flat down to 23Hz and without getting outside xmax at 20Hz. That should leave you some 110dB "distortion free" average sound pressure level and low frequency electronic music should be no problem. It could off course be driven harder, but then outside its (by definition) linear operating range. Add another sub and you gain 6dB of maximum sound pressure - four subs +12dB and so on By the way... this would also make a very nice sub for home use. A free and easy to use Excel tool is Kristian Ougaard's Unibox |
#3 | |
#4 |
Oh, thanks Quackhead... Didn't catch that the question was regarding double chambered bass reflex enclosure.
Then my answer is turned into a question, why not pick a proper designed driver with high xmax that does the job in a simpler box? |
#5 |
just another
You might want to have a read of this article by Claudio DCR
As far as I am aware the overall size of this style of DCR is no more than it would be for a single chamber bass reflex. The main advantage of DCR that I have seen mentioned is lower distortion. Tony. |
#6 |
What about the RCF L18P300-It's popularly used for p,a here but never seen in this type of enclosure...Ts here
http://http://www.rcf.it/products/precision-transducers/low-frequency-transducers/l18p300 |
#7 |
Just a reminder not to confuse the DCR on Claudio's excellent website, which has two chambers and three ports in total, with the DBR/DCAAV which has two chambers and two ports in total.
Different beasts. |
#8 |
AkAbak can sim a DBR... hope you have a lot of free time if you don't already know it.
#9 |
#10 |
Akabak should run under Win7 32 bit, but it does not run under Win7 64: at least, I haven't been able to make it go.
So I use it on my WinXP32 SP3 netbook, which works a treat. There is also a 'Virtual XP' mode included in Win7 Ultimate (I think) and there is a 'VirtualXP' downloadable from Microsloth which I have, but haven't been game to try on my 'real' PC. My system is very stable and I am reluctant to mess with the OS too much. |
| Visaton FR10 in Double Bass Reflex enclosure | activexp | Full Range | 11 | 8th September 2010 11:00 AM |
| Fostex FE107E Double Bass Reflex Enclosure | RemoGaggi | Multi-Way | 1 | 9th January 2009 12:25 PM |
| Double Bass Reflex. | Harderror | Full Range | 24 | 31st July 2006 10:57 AM |
| how to design a series tuned double bass reflex/ABC enclosure | Puggie | Subwoofers | 0 | 1st May 2006 01:47 PM |
| Double bass reflex information | Ilianh | Multi-Way | 26 | 28th February 2004 10:19 PM |
| Page generated in 0.13884 seconds (65.63% PHP - 34.37% MySQL) with 11 queries |
