I am not experienced with djing or PA, but the answer depends very much on what you want to acheive. For less crowded areas with limited distance to the crowd - why not?I am curious to know whether single 18" double bass reflex enclosures would be any good for outdoor djing and p.a uses if possible.I know they may turn out to be very large but just curious and which software can best model these with drivers and port front-facing.
If you for example take BMS 18N860 and use it in a 250 net litre BR cabinet and tune it to 23Hz, it could produce some 117dB/1m/1500W outdoor, baffle step diffraction loss taken into account. It's capacity extends relatively flat down to 23Hz and without getting outside xmax at 20Hz. That should leave you some 110dB "distortion free" average sound pressure level and low frequency electronic music should be no problem. It could off course be driven harder, but then outside its (by definition) linear operating range. Add another sub and you gain 6dB of maximum sound pressure - four subs +12dB and so on
By the way... this would also make a very nice sub for home use.
A free and easy to use Excel tool is Kristian Ougaard's Unibox
..hmm...come to think of it, I have never heard or seen anyone use a double bass reflex cab of any sort(that I am aware of). I am definately curious about the outcome of this thread...how is the efficiency with such a critter?I am curious to know whether single 18" double bass reflex enclosures would be any good for outdoor djing and p.a uses if possible.I know they may turn out to be very large but just curious and which software can best model these with drivers and port front-facing.
What about the RCF L18P300-It's popularly used for p,a here but never seen in this type of enclosure...Ts here
http://http://www.rcf.it/products/precision-transducers/low-frequency-transducers/l18p300
AkAbak can sim a DBR... hope you have a lot of free time if you don't already know it.
I'm very new at this stuff but I'm willing to try.Apparently v2.1is not compatible with win 7,where can I find it?
Akabak should run under Win7 32 bit, but it does not run under Win7 64: at least, I haven't been able to make it go.
So I use it on my WinXP32 SP3 netbook, which works a treat.
There is also a 'Virtual XP' mode included in Win7 Ultimate (I think) and there is a 'VirtualXP' downloadable from Microsloth which I have, but haven't been game to try on my 'real' PC. My system is very stable and I am reluctant to mess with the OS too much.
Possible simulations in AkAbak and Hornresp
Here are two items that may be helpful:
1. Don Hills did the work in AkAbak for the two chambers / three ports version, you'll have to modify the script(s) to fit your needs: http://www.diyaudio.com/forums/subwoofers/189223-crazy-box-design-input-please-4.html
2. I'll also attach a Hornresp export file for a two chambers / two ports (maybe Fostex style for lack of a better name) double bass reflex type enclosure:
- Subwoofers
- Double bass-reflex enclosure.
