Old 7th September 2012, 12:42 PM   #831
epa is offline epa  Netherlands
Originally Posted by Xoc1 View Post
Hi.
I would be interested to see how this driver compares with the above.
Would give more details but am posting this from My hospital bed
Regards Martin (xoc1)
hope its not to serius m8.
get well soon.
one good thing about music ,when it hit you feel no pain.
so hit me with music
Old 7th September 2012, 12:43 PM   #832
Xoc1 is offline Xoc1  United Kingdom
Xoc1's Avatar
Originally Posted by TundraLTD View Post
I do, I make a cad model of the cone and surround and baffle thickness and measure the volume to be used in my models
one of my early ones in sketchup format B&C 18SW115 w/18mm baffle
I think that the best way to apply the cone correction is to account for the cone volume and the baffle. The added areas can then be used with a simplistic Hornresp sim. Looking at the Danley designs the baffle is quite thick and the cone correction touches down to the baffle area. This implies that the baffle used is thick enough to accommodate the x_mech of the driver.
The thickening of the baffle is something that we have already explored with the fitting of a packing ring to increase the driver clearance. Of course it is easy to implement a different material thickness in a production product, but not so easy for the DIY'er who needs a decent yield from their sheet stock.
For a DIYdesign it may be an advantage to just go with the 18mm baffle even if this does not give such a good shape for the horn at the S2 point.
The methodology I am thinking of for implementing the cone correction is to work out a method that can be used by any DIY builder on any offset style TH horn.
This will probably result in a less extreme throat correction than in the Danley TH118. To clone this without any technical explanation or justification would be totally wrong in my opinion.
Regards Martin (Xoc1)
Old 7th September 2012, 01:39 PM   #833
tb46 is offline tb46  United States
Hi Martin (Xoc1) or Tom Danley (or anyone who wants to respond):
I have asked this a number of times, but have not been getting an answer from any of the experts: "why not use a throat chamber large enough to accomodate the motion of the driver plus whatever Hornresp/AkAbak tells us is optimum, and couple from there into the horn with an opening the size of S2?" Shouldn't a properly sized chamber load the driver more evenly? The shape of the opening could be changed to optimize flow characteristics. This would allow for easy manipulation of the horn parameters including the S1/S2 area. It might make it easier to manipulate the horn for different drivers. Basically, all the wood is already there for baffles and stand-off rings.
And second: "While the throat area in any horn design gets a lot of attention, should we not be watchful of what happens on the other side?" The motor/basket/cone blocks a lot of the horn duct, and the coupling to the mouth does not seem to be handled very cleanly in a lot of these designs.
I don't have your obvious experience nor the facilities to build and test multiple models, that's why I'm asking. I'm not asking for someone to design a TH, but just about the general design considerations.
Oliver
Old 7th September 2012, 01:44 PM   #834
jbell is offline jbell  United States
I think you are referring to the compression plate / cone correction. right?
A compression plate doesn't have to have it's opening in the middle, just has to have a smaller opening than the Sd of the driver.
Old 7th September 2012, 02:05 PM   #835
hi oliver .
i agree a throat chamber solves many problems.
the only drawback i can see ,is a dip is intoduced above ~100hz(in a 35~40 hz th.
not a problem when used only as a sub.
the mouth isnt so much an isu because the pressure being less(generaly)
thats just my 2 cents
Old 7th September 2012, 02:27 PM   #836
Xoc1's Avatar
Hi Jbell the V shape throat correction is the full width of the cabinet.
This is what makes it suitable for extending the middle fold in the SS15 / TH18 layout. The closer the V shape to the driver the longer path length that can be accommodated.
No visual examples as I am still typing this at the terminal at my hospital bed. At least I should be going home within an hour or so.
Old 7th September 2012, 03:37 PM   #837
Hi Martin,
Hope you get well soon!.
Oliver
Old 7th September 2012, 04:19 PM   #838
noSmoking's Avatar
Hi Martin,
I wish you a fast recovery!!!!!!!!!!!
Get Well soon!
NoSmoking
Old 7th September 2012, 05:02 PM   #839
NEO Dan is offline NEO Dan  United States
NEO Dan's Avatar
Originally Posted by NEO Dan View Post
Interesting results via Re+Res
15TBX100 606.37
18SW115 490.71
18SW100 398.93
18PZB100 664.26
15SW100 551.79
PD1850 716.9
Hi.
In My initial design I simmed with the Precision Devices PD1850.
This gave a lower efficiency which I hoped would be compensated for by less compression at war volume. It also gave a deeper frequency response.
For a minute there I didn't think you were gonna make it... Glad you pulled through m8
Dan
Old 7th September 2012, 05:50 PM   #840
noSmoking's Avatar
ooooo ouchh,*^%&%%%( I bet that hurt
2 18 bass design simpleacoustic Subwoofers 101 15th May 2011 09:22 AM
18 inch labhorn design. mulletdude Subwoofers 21 12th November 2010 01:40 AM
Ciare 18 bass horn design soundhead Subwoofers 1 28th March 2010 06:51 PM
I want my Avalanche 18 to go flat to 15hz thadman Subwoofers 10 11th November 2006 02:54 AM
Looking for suggestions on a 1300W Dual 18 sub design. mjcohen Subwoofers 5 21st December 2004 07:38 AM
Copyright ©1999-2013 diyAudio
