Old 11th May 2011, 07:35 AM   #1
Default 2X18 Bass Guitar Cabinet Help
Hello, I am new to this but I am attempting to make a 2x18 subwoofer cabinet that I can use for my guitar. I am going to use eminence sigma pro 18a-2 speakers.
power rating: 650watts rms; 1300watts music program
resonance frequency (fs): 28Hz
usable frequency range: 41Hz-2.4kHz
mechanical Q (qms): 8.28
Electromagnetic Q (qes): .30
Total Q (qts): .29
Compliance equivalent volume(Vas): 441.2 liters
peak diaphragm displacment: 695cc
Maximum linear excursion(Xmax): 6.1mm
I play alot of music that I want deep, booming, massive, loud, clear, Bass.
I have used a few online calculator for the enclosure and and came up with...
Height: 28.5 in.
Width: 46.1 in.
Depth: 17.6 in.
This makes the total volume of the enclosure 379.8 liters or 13.4 Ft cubed. the recommended enclosure volume is 3.3-7.5cu. ft for one so im guessing 6.6-15 cu ft. for 2?
My biggest trouble is tuning the ports. I have heard that the best balance between SPL (getting loud as possible) and SQ (sound quality) is about 32Hz so here are a few calcuation a i came upon on the web and said the minimum port diameter size should be 8.73 in. which seems a little big to me.....
but if i tried two 6inch ports the vent legths would have to be 6.71 in. in length. why is it the less quantity of ports & smaller diameter ports need to be shorter?
my questions are...
what kind of porst should i use?
how should I brace the inside for stability?
Will I need high pass or low pass filters? or crossovers?
should I have a fabric on the inside?
should i make the box the maximum manufacture recomended }volume(15 cu. ft.) to increase deepness?
should i consider bandpass?
i am looking for rediculously deep, clear, loud, massive booming bass, for reggae, hip-hop, rock music. any help or recomendations would be greatly appriciated. thank you.
Old 11th May 2011, 10:15 AM   #2
norman bates's Avatar
my neighbor loves his 4x10" ampeg. It goes deep and doesn't "fart out" as he says. It goes deeper than his ampeg 6x10" but the 6x10" gets louder (used in a larger room). His 4x10" box is tuned to 50hz if I remember.
This is more a question for the diy bass player forums.
Those guys do this stuff and try lots of drivers / boxes.
Norman
Old 11th May 2011, 11:45 AM   #3
chris661's Avatar
Think I'd try modelling the driver in winISD.
420L tuned to 40Hz does well (127dB@1m, both drivers at Xmax), though it's a pretty big box.
What's the lowest tuning this cabinet is likely to see?
For a E-standard tuned 4 string, you don't need to go below 40Hz.
Drop C# requires ~35Hz. I'd expect B to be around 31Hz, so if you're using a 5-string, that'd be the target.
The lower you want it to go, the bigger the cabinet will need to be. Also, you lose a little SPL the lower you go.
How much power is available to you?
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo
My setup: http://www.diyaudio.com/forums/multi...tang-band.html
Old 11th May 2011, 04:57 PM   #4
the cabinet can be tuned down to 29Hz. but a program I used online showed 35Hz. I think It depends on what size I adjust the ports to? I have heard that an 8 inch port is ideal for 18 inch drivers, but dosnt semm right to me. some of the online port calculators seem kinda wack.
I dont have have a power amp right now but am planning on buying one soon.
what kind of power amp would i need to get max potental out of this? together 1300 rms watts 2600 peak watts. @ 8ohms.
so maybe a QSC RMX 2450: Stereo: 500W @ 8 ohms, 750W @ 4 ohms, and 1,200W @ 2 ohms. Bridge mono: 1,500W @ 8 ohms, 2,400W @ 4 ohms?
or Crown XLS 2500: 1550W, Stereo, 2 Ohms (per ch.); 775W, Stereo, 4 Ohms (per ch.); 440W, Stereo, 8 Ohms (per ch.); 1550W, Bridge-Mono, 8 Ohms; 2400W, Bridge-Mono, 4 Ohms?
Old 11th May 2011, 05:50 PM   #5
chris661's Avatar
Looking at those, parallel the drivers to give 4 ohm, then bridge the amplifier.
You never said - what sort of bass or tuning will it see?
You needn't make it go to 29Hz if it'll never need to go past 40...
Old 11th May 2011, 05:56 PM   #6
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
FYI:
b
Old 11th May 2011, 06:07 PM   #7
wg_ski is offline wg_ski  United States
For an instrument application???? That's playing with fire. For both the loudspeakers and the amp.
Old 11th May 2011, 06:13 PM   #8
jogi59 is offline jogi59  Germany
You will be the nightmare of every sound-man.
There is a reason, why most bass-players today use 4x10 cabinets.
On stage you have to hear, what you are playing. Too much LF below 100 Hz does more harm then good.
Old 11th May 2011, 06:38 PM   #9
Stocker is offline Stocker  United States
Default Freak what you heard!
32Hz is not a magic number, and 8" ports are also not magic. Go download yourself a copy of WinISD Beta and model the response of various sizes boxes and ports. It is one of the better FREE calculators available that runs on a modern computer, and you can change the setup to see what trade-offs you will make to get what result.
The free "calculators" you will find online range from decent-but-limited to plain nonfunctional. Give WinISD a try.
Jesus loves you.
Old 11th May 2011, 07:11 PM   #10
lduarte1973's Avatar
why dont you use a 4x10" woofer box and a self amplified subwoofer ?
Build Guitar Bass cabinet BuildByHands Subwoofers 25 26th April 2011 12:58 PM
2x12" bass guitar cabinet boneless Instruments and Amps 27 18th July 2010 06:38 PM
bass guitar cabinet babagau Multi-Way 6 2nd September 2008 11:16 AM
Bass guitar cabinet at kappalite3015LF sokol Multi-Way 0 14th May 2007 07:19 PM
bass guitar cabinet wiring stupid m0nkey Multi-Way 3 8th March 2004 01:15 PM
Page generated in 0.10779 seconds (83.80% PHP - 16.20% MySQL) with 11 queries
