Fiddling with Hornresp - Peerless 831759
Old 3rd May 2011, 04:39 PM   #11
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
Originally Posted by Jmmlc View Post
Hello,
Here is my proposal.
Best regards from Paris, France
Jean-Michel Le Cléac'h
Hi Jean-Michel,
Yes this is a good option too:
b
Old 4th May 2011, 06:07 PM   #12
DrDyna is offline DrDyna  United States
DrDyna's Avatar
One more question, since I've never built any of these before, what would you guys suggest for wood? MDF? Ply? I know we're playing with resonances and wavelengths here, I don't wanna fry the whole idea by using something wrong!
Old 4th May 2011, 09:25 PM   #13
Hi, Use good quality 3/4" PLY and cross-brace :
PS: If the extra volume of the cross bracing is added to the enclosure, the volume saving holes can be omitted:
http://www.diyaudio.com/forums/attac...n-img_1959.jpg
b
Old 4th May 2011, 10:26 PM   #14
DrDyna's Avatar
b
Awesome, thanks again B.
Old 25th May 2011, 06:55 PM   #15
DrDyna's Avatar
One more question! I've started to play with some of this exported data in Hornresp, and using some information I've gathered from some posts in the hornresp thread, I think I've got the data exported properly, however it appears that the "width" decreases, which I expect, but it looks to me as though it's decreasing in both directions, which means the cabinet gets thinner as well?
I'm sorry about noob questions but this is my first try and I want to do it as properly as I can!
Old 25th May 2011, 07:27 PM   #16
DrDyna's Avatar
Does this look sorta how it should?
The measurements aren't right yet, I just kinda drew this freehand, but I want to make sure I'm on the right track!
Old 26th May 2011, 12:18 PM   #17
DrDyna's Avatar
b
Bjorno, my exported horn data has got to be incorrect. I've been reading tutorials all morning and I can't seem to come up with good measurements to use so that I can model this thing to the right scale.
Old 26th May 2011, 02:27 PM   #18
I'm very busy for the moment... but I made a quick drawing that may help a bit..
b
PS:I haven't used the exported HR data yet, Round off (up) my given dimension numbers to 1/8" ...I'll be back later...if you have more questions.
File Type: jpg Preerless-831759_T-TQWT-quick-layout.JPG (126.9 KB, 358 views)
Old 26th May 2011, 02:42 PM   #19
DrDyna's Avatar
b
Haha! Thank you very much! I was off by quite a bit, here is what I came up with this morning. I'll make another model with these new dimensions if you want to check it out later.
Old 26th May 2011, 07:07 PM   #20
DrDyna's Avatar
Let me know what you think B!
Fiddling with Hornresp - Peerless 831759Hide this!Advertise here!
Hornresp David McBean Subwoofers 8362 16th June 2018 07:08 AM
How do I use Hornresp? Boscoe Subwoofers 4 23rd November 2010 09:00 PM
peerless xxls sealed -vs- peerless xls with passive radiator Naudio Subwoofers 8 23rd March 2008 09:00 PM
Whats the difference between the Peerless 831916 and Peerless 850122 SkinnyBoy Multi-Way 9 12th June 2003 03:11 PM
