#101 |
Way back in post 7......
I commented that the 135mm dimension close to the horn mouth seemed small in comparison to the expansion of the horn. Martinsson replied in post 10 that this dimension was intended to keep a longer L23 length. I did a best fit the horn as Martinssons original drawing, and inputted the straightened dimensional data into hornresp. This sim then shows a massive dip at 165-170 hz. I then reworked to get a linear taper throughout the L23 section. I retained the 135mm dimension. I did increase the S2 compression slightly from 2.18 to 2.46 This filled in the dip by 5db and made the dip W shaped. Attached Hornresp sims and reworked dimensions Hope this helps
#102 | ||
Hmmm... interesting you brought up the SPUD... let's investigate that a little bit shall we? Quote:
Hmmm.... seems like danley is saying akabak doesn't show you everything, and hornresp agrees with akabak.... hmmmm..... Also, wonder what function you think sound absorption accomplishes in this location? hmmm.. maybe eliminating some unwanted 'reflections' or 'standing waves' ???? In a HT setup where total spl is not the goal, absorption is an option, where every db is precious, reflection is a better choice. ![]() from here: http://forum.realmofexcursion.com/en...ts-10-kit.html hmmm.... AND if you follow the diyaudio thread from danley's quote above you'll see where adding additonal absorption where it wasn't necessary created a dip that hornresp said shouldn't be there, and when removed the dip was removed..... How do you suppose absorption created an extreme dip? shouldn't it have just lowered the total spl only? Hmmm... sorry, but not buying your TH-SPUD argument. |
#103 | |||
![]() Quote:
No. The level of absorption of most materials doesn't remain the same as frequency changes. Among other things, it's frequency-dependent. Also, a TH's response is the combined response from both the front and back of the driver and the use of absorbtion changes the relationship between these two, and as a result the combined result will also change, in a way that can't be predicted by HornResp. |
#104 | |
There ARE things you have to do in band in a TH in the folding process.... There ARE things you have to do in band... (repeat, repeat, repeat) In the 12 step approach, you'll never get to step 12, until you start at step 1. |
#105 |
Where did the 160Hz dip go?
Don |
#106 | |
#107 |
#108 |
#109 |
Bumping up the volume, different driver, dual taper ... I'm sure all had a part in this mod. All these boxes are about 21 inches wide, and
reflections/cancellations happen side to side as well! I guess that I'll just have to make one of these and see how well it compares to the sim. Brian: Hornresp sims the schematic layout ... we won't know what effect the folding has until we build one. ~Don
Don Last edited by Don Snyder; 24th January 2011 at 03:31 PM. |
#110 |
Don; What was your mod to THAM15? to get that sim? Andy
| 15" tapped horn with RCF | wood1y | Subwoofers | 123 | 15th June 2013 10:48 AM |
| Infinity BETA 15" sutable for a tapped horn? | Jimjim | Subwoofers | 13 | 13th September 2010 02:05 AM |
| P.O.C. #2 - Compact Tapped Horn | Brian Steele | Subwoofers | 17 | 18th September 2009 08:27 PM |
| Compact 15" sub - BMS or Precision Devices? | DIAR | Subwoofers | 7 | 4th January 2007 04:06 PM |
