I impulsively bought this woofer... - Page 4 - diyAudio
Old 30th September 2010, 09:56 PM   #31
I think this may be a good reason for endorsing the larger size drivers like OP has in his hands. And avoiding big-movement-in-hearing-range boxes - like tuned boxes. And avoiding 8 inch subs with enormous movements.
BTW, if concerned about Doppler distortion, TRUE horns and ESLs are the way to go.
HiFi aspirations since 1957. Currently working on motional feedback again... the final frontier in audio
Old 30th September 2010, 10:58 PM   #32
lazzer408's Avatar
Speaking of ESLs I LOVED mine. LOVED LOVED LOVED LOVED. They were Acoustats. I powered them with a Carver. They were big but close your eyes and they vanished. Acoustically speaking. Had to sell them when I moved.
What's a "true" horn? Do you mean folded horn subwoofers? On that note this 18" would be unreal in a horn. I'd need a longer house to enjoy it.
Old 30th September 2010, 11:38 PM   #33
Should use an 8" vent... keep the airspeeds and distortion low. You can afford to as youre already using a big box.
Old 1st October 2010, 01:13 AM   #34
lazzer408's Avatar
I think a smaller port sounds better. Large enough not to huff air of course. If the port is too large I find that the reflections inside the enclosure escape right out the port and I get a "shoe-box" sound even if it's tuned correctly. In a PA or automotive system I'd be all for it but not for a home theater. Maybe because of how close the listener is. Across the yard you'd never hear it.
Old 1st October 2010, 03:21 AM   #35
Not a "tapped horn."
Old 16th October 2010, 02:29 AM   #36
lazzer408's Avatar
I had a chance to build a couple of enclosures to test this speaker. One is a 6.6 cubic ft. 24" cube with two 4" diameter ports 6" long (34hz). The other enclosure is 4.72 cubic ft. 24" tall, 13" wide, with 33" depth. One 6" port 10" long in front (34hz). Speaker in the side.
The cube box is ungodly loud. @.@ 100w rattles everything in the livingroom. It would be great for sound reinforcement but lacks deap bass. It's very "punchy" and kick drums slam your chest. I ran out of 4" pipe to try longer ports.
The second enclosure is sort of strange. If I use a shorter 4" long port (44hz) the deep bass extends lower then with the 10" port (34hz). I'm not sure why. I haven't had a chance to drive it hard yet. The kids went to bed.
Old 16th October 2010, 03:48 AM   #37
lazzer408's Avatar
Pics...
Old 16th October 2010, 04:36 AM   #38
Wow. If you're thinking about a port that big why not consider a PR and avoid the majority of the fluid losses associated with a port the size of Texas?
Old 16th October 2010, 04:38 AM   #39
Are we talking about ESL's and subwoofer frequencies? I thought they had trouble with bass let alone sub-bass...
Old 16th October 2010, 06:03 AM   #40
lazzer408's Avatar
An 8", or even some 6" subs, can out perform most ESLs when it comes to bass. ESLs can't move a large volume of air so the bass will seem lacking but they are playing it. I had a set that didn't have a seperate subwoofer and although the bass from the panel couldn't shake walls, they were so smooth and pleasing that I didn't bother to turn on my powered 12" unless I was watching movies. Funny thing was more bass from behind the panel then in front and if you stuck your head back there it was incredible. Better then any sub I've heard. Too bad nobody makes an enclosureless ESL subwoofer.
Bought a woofer, need help finding suitable enclosure Simpleton Subwoofers 12 11th May 2007 02:42 PM
Bought a 4" woofer... BAM Multi-Way 5 8th September 2003 02:49 PM
Qts of Push-pull woofer and Compound Woofer System... haggy Multi-Way 1 13th December 2001 01:30 AM
Copyright 1999-2017 diyAudio
