#431 | |
#432 | |
Using the same TH model, it sims the same in the low end (Xmax is the same for both speakers), needs a bit more power to be as loud (but is rated for the extra power). It has a few different bumps in the upper end. It weighs more too, a disadvantage when hauling, but perhaps a slight thermal advantage as there is more mass to heat up. I know from having heard the Low Riders in tapped horns they do perform quite well. The 4015LF still appears to be a slightly better choice, other than the cost. One very nice feature of the Low Rider is a replaceable basket/cone/vc assembly, you can do a "recone" in a matter of minutes with just a wrench. The basket costs little more than most recone kits, which require a fair amount of skill to install, not to mention the time to remove and clean up a used basket. The Hornresp script with the Peavey Low Rider 15 Specs is attached. The Low Rider 18 works OK in the SS15 sim too, with a couple dB more level at 60 Hz, and a couple dB less at 100 Hz, but no improvement down low. Last edited by weltersys; 18th February 2011 at 11:03 PM. |
#433 |
A dozen 3015LF are $104 each from martinsoundpro.com, the 4015 about $139, the Peavey is more$ from what I can see.
Candidates for the Darwin Award should not read this author. |
#434 |
Any comments on post #430? Thanks.
Sam |
#435 |
If this gives a lower cutoff frequency, but still better output per cubic foot than the stadium horns, I'll be making lots of sawdust!
Regards, Ben |
#436 |
samuel:
Of the 4 pics you linked to, only the last one is of interest to me. I haven't tried it yet (waiting for warmer weather) but it should play just a bit lower and at about the same spl. It's 1" shorter at 29" and you have to splice one panel out of 2 boards to get the entire thing out of a single sheet. An additional downside to that you need to cut braces out of scrap material, so it's not truly a 'singlesheet' design anymore. Don't even try the cube, while it's flatter to 40hz, it's overall spl is VERY low compared to the ss15. I really haven't played around with how to maximize 40hz in this size cabinet, while abandoning the singlesheet concept. |
#437 |
I'm guessing the next challenge will be:
Maximum bass out of a fixed volume enclosure, wood be damned! (e.g. 8 cubic feet) ![]() Can't say how often I've read these threads. The interest in the SS15 plan is increasing. Over at speakerplans.com someone is building the SS15, but no results reported yet. |
#438 |
I did not get much (any) interest in a the competition suggestion for a one and a half sheet design that could go lower and/or louder.
Is anybody up for that? A Mars Bar for the winner if Customs allow it through. |
#439 |
Is that a legendary deep-fried mars bar?
#440 |
It can't be hot if delivered by post (snail mail) and I haven't found a way to Email them yet.
Scotty "beam me up". |
| Here is a Challenge | latala | Solid State | 41 | 12th May 2011 01:13 AM |
| Renovation Challenge | ZirconiumZephyr | Multi-Way | 16 | 1st September 2009 08:38 AM |
| Design Challenge #1 | kgillies | Subwoofers | 12 | 13th June 2007 03:20 PM |
| a challenge --or I need help | lawrence99 | Car Audio | 0 | 9th March 2005 04:44 AM |
| The challenge ! | thylantyr | Solid State | 51 | 24th July 2003 08:41 PM |
