#11 |
Hi GM
Yep this is a killer sub. But a TRIO12 and a tapped horn do not work together. Not the right application for that driver. If I find the right driver it would be an interesting design competition. But so far I have found drivers that model well in a true tapped horn that fill up fewer than 5 fingers! Most of the tapped horns are just tappered quarter wavelength jobs that the designer thinks is a tapped horn. Hey Brian Thanks for the complement. It was a exercise in cheapness. I spent more money on the 5 tubes of Pl Premium adhesive than I did on the 4 sheets of 7/16" OSB! But it proves a concept. The TRIO 12 is an excellent driver if you know how to load it properly. Well made and a pretty good price to performance ratio. I do have a few kinks to iron out of the box but other than that I'm quite happy. Mark
Mark |
#12 | |
Just something to consider if one uses a very high compression. If you're clever, you can really use it to your advantage, since the drop in FS can lower your F3. But the bump in QTS can change the response of the entire horn. |
#13 |
The cone of the MCM is kinda flimsy, and my "Triple 8" tapped horn uses a high compression. While trying to find a leak in my horn, I decided to seal off the cone of the MCM. (The magnet of the woofer was vented, and I was worried that minute amounts of air might be leaking through the cone and the surround; they're very lightweight.) I used Titebond II wood glue. It worked out really well; the change in Thiele Small was negligible, but the cone is noticeably stiffer now. I applied it to about half of the surround - it might prevent foam rot too. Who knows?
#14 | |
Long time no hear! Hmm, it looks pretty good to me, but it's so small, ergo lower efficiency, it will take four drivers to get near its efficiency/bulk. Well, they are tapped horns since they expand, just not ideal tapped horns. True, the vast majority I've posted are tapped 'BIB' pipe horns since I wanted them to perform well and ~as predicted while not giving away any of the finer points of DSL's designs in any more detail than TD already has. This assumes of course that I have a clue, which remains to be seen until I can build/measure a few. Yeah, I've found some that it takes two/horn to make them big enough to mount the drivers. Anyway, the driver specs for your design are so far from what's published that to call it a TRIO12 is a gross misnomer at best, so what gives? GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#15 | |
This is a truism. GM
#16 |
Hi GM
WHat gives for the specs is mee posting the wrong screen. I did some work on the same box with an RCF driver. So attached is the right screen. The bottom end is a bit more wavy but not that much different. To many jobs to do and not enough time to do it! I wanted to see the difference between a high efficiency driver and the TRIO 12. Not that much actually. Agree on the tapped horn's posted. And further agree on the right of Tom Danley to make a living without anyone undermining him. Two true horn designs have been posted. One was a direct drawing from DSL and the first one was an actual derivation from the DTS 20 I believe the Tower of Power one. Again you need the driver. Without the driver the speaker will not perform properly. Now I have to cchase down a glue block that failed to bond properly. Haste makes waste! Now I have to remove one side of an enclosure that was never made to be removed! Chainsaw time! Mark
Mark |
#17 |
Greets!
Dang! I was hoping it was a prototype Bob was considering offering. Oh well....... which RCF is it? Anyway, glad you've plenty of business, it's an increasing rarity around here unless you're willing to work for minimum wage (or less in some cases).There's been a sim of at least one other......... Bummer, I hate it when that happens. ![]() GM
#18 |
Oh there are prototypes coming. But this is an existing driver.
What happens with most drivers and tapped horns is a very large box and almost no gain over a conventional enclosure. There are but few drivers that can be massaged into a true tapped horn and actually have proper gain of 7 to 8 db. 130 to 140db for home use! Ouch! This would be interesting. Break windows but hey glass is cheap. Have to do the chainsaw surgery after I write this. RCF driver was LF12N401 Not a bad driver if you don't mind the price. Mark
Mark |
#19 |
See what happens when you work to fast. You get to do it over again. Oh boy!
Mark
Mark |
#20 |
Nice folding, good work!
I didn't see in pics but I supose the first portion of the flare (those two panels close to each other) is well braced like the rest. I said this because there is expected to be the most high dynamic presure load of the entire structure. Regards, Dorin |
| Front loaded and back loaded horn | DrWoofer.com | Subwoofers | 0 | 3rd August 2007 06:55 PM |
| Front loaded horn concepts | rabw | Full Range | 62 | 25th May 2006 12:17 AM |
| Front loaded horn sanity check | Volenti | Multi-Way | 9 | 14th January 2006 05:50 PM |
| Commercial Front Loaded Horn Loudspeakers | rabw | Full Range | 44 | 14th December 2005 11:11 PM |
| help with front loaded horn designs -please | juddr | Multi-Way | 8 | 15th November 2004 09:02 PM |
| Page generated in 0.12014 seconds (82.53% PHP - 17.47% MySQL) with 11 queries |
