Hi all,
I'm looking for a 15 with reasonable xmax to load into a fairly small enclosure of ~80L with EQ. I have a BASH 500W amp with EQ, and a standalone EQ unit as well. It'll be used for LFE 80% of the time, perhaps music very occasionally. It seems tough to find a large driver that works well in a fairly small enclosure. Looking for recommendations. Thanks guys. |
#2 |
AV15-X from AE Speakers. John is a great guy and will have a driver that will work for you.
#3 |
Thanks, not a bad looking driver. It's 15db down at 20Hz which might need too much EQ. If I can get something into ~80L that's about 6-9db down at 20Hz that'd be ideal. Think this might be too much to hope for, for a large 15" driver?
#4 |
Have you thought about using a Linkwitz Transform?
15dB is about the max recommended gain for a LT circuit though, and it will eat up most of your SPL headroom.
"If you don't like funerals don't kick sand in Ninja's face." - Ninja |
#5 |
Yes I have built-in parametric EQ in the amp, as well as a standalone unit with sweepable EQ. I'd be using that to boost the low end in that fashion. Just need the right driver, that'll give me reasonable response in the smaller enclosure, and I can make it perfect with EQ. I'm hoping to find a driver that'll play -6 to -9db down at 20Hz in ~75L. wow 15db gain, that'd require a monstrous amp. I've already found a driver that's 9db down at 20Hz vented. I'd like to go sealed, and I haven't found a suitable driver for that yet..
#6 |
Hello mike,
curious that your thread should show up at this time, as just yesterday I was searching for such a driver myself. I was looking for something that could do about 106dB in an 80l sealed box with LT, and get all the way down to 16-20Hz. I was putting a few drivers through WinISD, but didn't really find any I liked. This is not a high priority task for me, since I'm already working on several other subwoofers right now, but I will be following this thread with interest, to see if anything else useful comes up. I hope you report back on any progress you make. |
#7 |
Looks like it might be a tough (if not impossible) goal you're after.
I've been playing around with sims of various 15" drivers and the best I can come up with for a 80l box is -11dB @ 20hz.
#8 |
your maximum SPL is governed by Xmax and Sd.
If you want a target 20Hz SPL then do the sums and find what combination of Sd and Xmax are required. Then find what power is required by the driver to reach that Xmax in an 80L sealed box.
regards Andrew T. |
#9 |
I use a jbl 2226H in 100L enclosure and I have been using this for quite a while.
Try simulating this against your driver of choice. Fx 2226H vs some peerless XXLS give nearly the same output(1W) at 20Hz, whereas at 50Hz the 2226H wins, clearly the XXLS wins spl wise due to the longer XMAX. Thus if not considering XMAX, both drivers will play equally loud per watt at 20Hz. The 2226H needs EQ something like -15Db at 100Hz to become linear. AE speakers have a special line suited for non-Eq'ed closed box systems. However it is not on their website, it is, however mentioned in several posts on their forum /andreas |
#10 |
Hi all,
FYI: Looking for a 15” driver(EBP<=50) suitable for an 80 L closed box LT:ed to 20 Hz but not wasting to much power i.e. a max. total power loss of less than 4 times or 4:1 = 12 dB? ~106 dB at 20 Hz at x-max is achievable when inputting 640W/ref 4Ohm into a Aurasound NS15-992-4A driver in a 80 L closed box, thus for an 4:1 LT – amp connected: 160W would be available for the midband SPL . See the picture for the LT circuit. b |
| Hi-Q speakers, small boxes, DSP-EQ & phase | Horn_aficionado | Full Range | 12 | 28th September 2010 01:10 AM |
| Help me align this 15 in a vented enclosure? | mpmarino | Multi-Way | 8 | 4th August 2008 06:06 PM |
| 15" woofer in sealed enclosure | KCCT82 | Multi-Way | 23 | 18th January 2008 03:45 PM |
| Enclosure for EARTHQUAKE BALLS 15 | Tony.ca | Car Audio | 2 | 18th November 2003 06:21 PM |
| Eq for small XLS | griff | Multi-Way | 5 | 10th July 2002 03:55 PM |
| Page generated in 0.08844 seconds (84.76% PHP - 15.24% MySQL) with 11 queries |
