#2861 | |
I also notice it changes it from TH to Nd (whatever that may be) Last edited by Silent Screamer; 3rd October 2012 at 06:42 AM. |
#2862 | |
* high efficiency * good low frequency extension * small size Nd means number of drivers. Double-click in the Nd box to change the driver configuration. (or use Tools -> Driver Arrangement). -Bjørn
Dynamics to the people! |
#2863 |
20-50Hz in 326.5 liters
Regards, Dan |
#2864 |
Thanks Dan, looks like it can be done but as Kolbrek pointed out it did come at a cost... which was SPL.
So am I right in assuming that TH is not really the right cabinet for sub work then? |
#2865 | |
![]() b
#2866 |
I believe I may have been a bit hasty in that call... Although it is 577 litres compared to just a 103 litres of a BR cabinet, the tuning does seem a fair bit lower. (using LMS Ultra 5400 data as that is the planned sub drivers)
#2867 |
Dear Mr. McBean
I think this is the third time I've made this request and I'm sure I'm not the only one. You are probably sick of hearing it by now but please let us have more segments. IIRC the last time this was formally discussed, you didn't see any way to add more segments without messing up the format of the input screen. I think you mentioned that Akabak was available if we wanted to simulate more sections. But since Hornresp has been able to simulate PAR sections and Akabak can't it's become undesirable to rely on Akabak. Here is a suggestion on how it can be done without changing the input window. Below is a picture of Hornresp, I've circled Ap1. Clicking Ap1 changes the label and context of those input boxes. What I propose is clicking on S1 in the same way, and having that switch the segment input section to display S5 - 10. In that way you could allow infinite segments without changing the look of the input window at all. Every time you fill up the available segments, double clicking the segment label would give you more segments. Once you stop adding segments, double clicking the segment label would go back to S1 and subsequent double clicks would scroll through all the defined segments. Hope that makes sense. ![]() Please consider it. But even if you don't, thanks so much. I love Hornresp. Last edited by just a guy; 3rd October 2012 at 04:14 PM. |
#2868 |
SS, looking at the attachments in your post with the Bass Box Pro design. You do have a box that is 104 litres.
However, unless I'm reading it wrong, you also seem to have a port that is 4936mm long with a diameter of 274.2mm. This is an extra 291 litres of port |
#2869 |
As you point out, Hornresp has a limited number of sections available. AkAbak allows many. Define a series of waveguide sections with dimensions following the parabolic law. Close enough for rock'n'roll...
#2870 |
Sure, it's possible and not even that hard, but are you really voting against more segments?
While not terribly difficult, the method you describe requires quite a bit of time, every time, for every segment of every model. I'm guessing the proposed upgrade would be a lot simpler to implement than a lot of the recent upgrades so I had to ask again. Last edited by just a guy; 3rd October 2012 at 10:42 PM. |
| Hornresp Class | FlipC | Subwoofers | 8 | 3rd November 2008 06:23 PM |
| Some questions about hornresp | brsanko | Full Range | 4 | 18th October 2008 09:36 PM |
| Hornresp help / JX150 | 316a | Multi-Way | 0 | 11th February 2004 03:56 PM |
