#491 | |
Account Disabled
#492 | |
The one and only
that .04% is going to sound bad, I don't expect the circuit as described to have that "feature", certainly no amplifier with a 1 Amp bias.
#493 |
In case that 0.04% is crossover distortion in nature, it is pretty audible.
And yes, 0.04% is quite high distortion. It would not if it was only 2nd harmonic. |
#494 |
I think Estuart is referring to a Cherry-esque second miller loop containing the output stage, with an R in series so that the traditional miller loop becomes dominant at high frequencies to maintain the original stability.
#495 | |
Account Disabled
#496 |
Hi PMA,
Without the circuit you cannot expect me to guess what might be going on ! I wonder if I am expected to think that plot is satisfactory ? There is an error in #474 at higher audio frequencies, and this is of greater magnitude than the Symasym for most of the time. Of course we get greater error voltages with tube and non-feedback designs, and this error voltage variation in time (which is generally far greater than resistively measured THD figures) contributes towards making amplifiers sound different. Cheers .......... Graham. |
#497 | |
Exactly, that’s the crux. Chapeaux! See below for this simple but valuable trick. Note: It doesn’t work without a preceding beta enhancement transistor in the VAS stage. Probably, that’s why D. Self misunderstood the potential of this subtle modification. Cheers,
Een volk dat voor tirannen zwicht, zal meer dan lijf en goed verliezen dan dooft het licht…(H.M. van Randwijk) |
#498 |
Using a resistor from output to Darlington VAS base can also help to reduce output stage crossover distortion and improve NFB response by flattening the open loop bandwidth.
Using an equal value resistor from other half of mirror to ground prevents start-up thump and preserves differential input balance. This is a Sim demo cct only. Cheers .......... Graham. |
#499 | |
Account Disabled
#500 | |
Exactly right. Bob |
