#71 |
Thanks for the info.....have been a great help. I'll take it from here.
long live diy-ers! |
#72 |
Hello diy-ers,
I have built the white noise audio (MOS100) with the above mosfets. They sound very good. Input FET opamp. You should try it. Cheers. RSK. |
#73 | |
Hi RSK, Any links for this amp? Thanks, JojoD |
#74 |
#75 | |
RSK, Thanks a lot! Regards, JojoD |
#76 | |
also has got a little forum at http://www.audiocircle.com/ White Noise Audio - board http://www.audiocircle.com/circles/index.php?board=36.0 but not much used right now, it looks
lineup |
#77 | |
is using an OPA604 op-amp for input and gain control and two very high quality Lateral MOSFET for output. As the output has got voltage gain of 4-5 ( common Drain Push-Pull ) the output voltage can be higher than OP-Amp can produce. See my attachment schematic of White Noise Audio AMOS100 lineup
lineup |
#78 |
lineup,
Wasn't it mentioned somewhere that Lateral mosfets cannot be substituted with hex? But RSK was able to build it with hexfets so no problem there. Do you mean opamp has not enough voltage swing? |
#79 | |
without any danger. This is has been explained in detail in previous postings in this topic. By me as well as other posters. Also is many other threads at this forum with such warnings to use HEXFET in some circuits. ===================================== If we focus on AMOS100. Schematic in my last post here above. This circuit uses Tr2, a VBE-multiplier, to control the idle current in driver stage. Tr2 should be place onto heatsink to sense the temperature. When heatsink gets too HOT, then Tr2 will reduce the current in Tr4 + Tr5. But this case control is NOT directly to the output MOSFET. It only controls current level in Tr4 + Tr5 = the drivers. But the drivers current will effect MOSFET, by changing voltage across R13 and R16. I would say this AMOS100 is a borderline case. It might work with HEXFET, but best is of course to use same Lateral MOSFET as in circuit. Because this is what it was designed for! I would, to avoid problems, build AMOS100 exactly as is intended. And careful read and follow instructions in the good documentation PDF. ----------------- Generally Op-amps have a recommended max supply around +-15 to 18 Volt, so this means that most op-amps will not be able to produce an AC output voltage more than like +-15 Volt peak. In AMOS100, OPA604 is supplied with +-15 volt, set by ZENERS ZD1 and ZD2. So an output like 8-9 Volt RMS would be maximum, from OP. But because the 4 transistors at output has got a voltage gain of like 4-5, set by (R19+R20)/R20, the total max output voltage of AMOS100 will be well up to deliver 100 Watt RMS. ** 8V RMS into 8 Ohm would give 8 Watt. ------------------ Advice: You may try to use AMOS100 circuit using HEXFET like IRF240, IRF9240, and there is a chance they may work. Most probably for best result, even if they work, you would have to modify output stage a bit. To fit HEXFET better. But my advice would be to try and find An Amplifier Circuit, that was originally designed for HEXFET use and even best if using IRF240-IRF9240 or very similar transistors as standard devices, from the beginning. regards lineup
lineup |
#80 |
Wow, quite a thread considering it started with a simple question about some IRF devices.
Just today I listed to my audio system for a couple hours which includes an ADCOM GFA-5500 power amp. It's a great sounding, powerful, dependable amp that uses IRF9240 and IRF240 output devices. And, it also happens to have been designed (mostly, anyway) by Mr. Pass. So, I'd say yes, those devices can be used to build a good sounding amp without too much difficulty. While my GFA-5500 is not a simple design, it's not very complex either. I have the schematics and they're pretty cool, unfortunately I can't post them for reasons already mentioned. So, before you get talked out of using the IRF devices by people who practice audio-sorcery, I’d locate a few amp designs from this forum, pick one that’s reasonably based on science and within your capabilities, and build it. It feels good to build something, is fun when it works (if it works : ), you’ll likely learn something new, and it will probably sound decent. You can’t listen to schematics and forum threads.
"Believers cling to the myth despite the evidence, reinterpret the myth to suit the evidence, or lie about the evidence to support the myth." "To err is human; to blame errors on external factors is even more so." |
| IRFP240&IRFP9240 power amplifier schematic | mos | Solid State | 30 | 19th October 2009 12:45 PM |
| IRFP240 / IRFP9240 MOSFETs | danieljw | Swap Meet | 8 | 4th July 2009 01:51 AM |
| Wtb: Irfp240 / Irfp9240 | folkeb | Swap Meet | 1 | 10th March 2009 10:18 AM |
| IRFP240 + IRFP9240 -- pairs | jackinnj | Swap Meet | 1 | 2nd June 2006 02:22 AM |
| IRFP240 and IRFP9240 Wanted | richeros | Swap Meet | 1 | 9th November 2002 12:38 PM |
| Page generated in 0.15967 seconds (69.63% PHP - 30.37% MySQL) with 11 queries |
