Do you charge a fee?
Thanks Again.
No, for free!!!!!!!!!!!
Send PM with E Mail adress.
Regards zeoN_Rider
Can't do PM to you .....don't know why, anyhow iquirke@bigpond.net.au thanks again, very kind of you. I will let you know what I find. Cheers
Is stoN_Cold still online? If so - can you share schematics for PHONIC Powerpod 7 - specifically looking for the power amp module that attaches to the STK4040V amp chip.
Got one with varying DC on the output (.850V ... 4.5V depending on turn on/off cycling)
I'm trying to figure out what the additional components are used for - have swapped all the transistors and some caps between the two boards and still same?!
Hi, Just been reading your old post regarding the Phonic Power POD7 and wondered if you have a schematic diagram for this model, please? The problem with mine relates to the protection IC (TA7317P) which is not turning on the speaker relay. If I manually power the relay, the unit works fine. Any help would be appreciated.hi audiomac!
What type of POWER POD is , if is 740, this product don't have STKor similar hibrids. Isaid one more thime: I, have all service manuals for PHONIC product.
Ciao!
Geoff.
- help Phonic Powerpod7
