john curl said:I would put a 5-10 ohm resistor in parallel with the output inductor (2uH). Everybody does, for good reason.
............not necessary (and not good!) if the entire Theil network is properly designed..
hi MikeB
Thank you very much!!!
honestly I prefered your previous one, but this one is nice too!
but seriously
as you use ac input source the input cap filters HF so at output you have low amplitude of HF. This may 'mask' the local maximum in freq. response (read unstability)
try repeating ac sweep without it
regards
but seriously
regards
That's right, I also had a couple of cases when I had to remake frequency correction in my AB-amplifiers 'in real life', after it seemed to be defined well during simulation (I used Microcap 7 program and models), although p.c.b. layout was done very carefully regarding parasitic capacitances etc.
Anyway, basically this conception looks 'fresh blood' to me and I appreciate your idea Mike. I hope there would be no big problem to eventually add some RC in this amp and it won't shoot its brilliant performance
Eva said:Don't trust nor rely on simulations at high frequencies, the usual transistor models are not valid at RF. Non-linear capacitances and storage effects are not simulated propely
And it doesn't care with the leakage capacitances, and inductances, which can be problem on higher frequencies.
But well designed amplifier, with large phase margin will be stable in real life!
sajti
MikeB said:For final confusion...
I sim'd with 33pF across the 22k in feedback, attached are the
resulting phasehifts.
Green is output, red is feedback, blue is input and yellow difference
between phaseshifts of input and feedback.
Now it never reaches 180° ??? This circuit drives me crazy !
Mike
Crazy? Why? It IS called a phase lead network
Jan Didden
Yes, i also had this experience, circuits beeing stable in sims, did
oscillate like hell in real world. (up to audible levels)
I just did not detect oscillations yet, and what i tried to show with
the sims is that there is no reason for this amp to oscillate...
I've had that experience AND the opposite. I've concluded that using an AC analysis to predict phase margin is a waste of time.
sam9 said:
..........using an AC analysis to predict phase margin is a waste of time.
It's only a first step to establishing stability...need to perform transient analysis...thereafter:
http://www.enel.ucalgary.ca/People/Haslett/Enel647/ReturnRatioStability/rrSim.pdf
Hi Mike,
I have been thinking about why your amplifier is not oscillating, and I think the answers are
No common emitter stage; ie. less inter-device hf phase shift / feedback from your differential + cascode + mirror + follower output.
The differential is working harder than is often the case when driving a VAS etc.; ie. collector current variation is a much higher proportion of tail current than normal. With higher input impedances for this stage it has less hf capability (gain) for stray voltage field pick-up to influence the cascoded outputs.
From your posts it looks as if you have put the simulator generator directly to the input transistor base; this will give you different amplitude - phase - distortion responses to what happens in real life. You must feed through the input resistors + capacitor.
Jan's comments have been relevent. Where do you measure your output ?
Before the choke is not the same as at the load.
Also have you tried distortion simulation with a virtual loudspeaker in place of the resistor?
Why is the choke fitted, does the amplifier not work without it?
Cheers .......... Graham.
mikes,
Thanks for the url. I recall asking for info on the topic about 3 years ago and getting little response, but this had not been published at the time.
Since I tend to build on earlier designs that I know work, I've adopted a practice of starting with a Miller cap that large enough that I'm 90% sure will be stable, then when the rest of the design is functioning, I decrease the cap value until either instability sets in (in which case I retreat a step or two) or it's low enough that I don'e believe there is any practacl advantage to going further. Of course, one has to keep track of tail currents at the same time, but there is some latitude so that they don't need to be changed with each step.
If I could do a better prediction in Spice, I could be braver with trying out new ideas.
Hi graham !
Yes, the idea was to reduce voltagegainstages to reduce delays.
This "melts" diffamp and vas into a single stage.
In sims i only placed the probes at the bases, the feeding was
normal, visible as the input get's a 90° shift for higher freqs.
I placed the probe before outputchoke to be sure HF is not filtered out.
The amp needs outputchoke to be stable into capacitive loads.
I haven't tried speakersim yet, but will do !
Mike
Mike
I think that delay is not so important, if You apply low overall feedback. Use local feedback to set the gain stages linear, and reduce the overall feedback to the minimum. I think, that 12-16dB is enough. Of course the distrtion will be higher, but there is no problem if it goes up to 0.2% from 0.02%....
sajti
sajti
- Ultrafast NoCap-ClassAB
