Hello All
I am planning to build the Citation 12 from the HK manual. Could you suggest suitable replacements for the obsolete 40408, 40594 and 40595 transistors? It seems to me that the specs for the 2n3055 closely matches those of the 40636.....what are your thoughts? Appreciate any help you can give. |
#2 | |
I'm just wondering what your looking for with this? A copy that is as close as possible, low cost? It's probably one of the most common and copied designs out there, it is very close to the reference design from the very old RCA transistor manual. I built it from scratch over 30 years ago. It would make sense to build it as a complementary design today given the availability, but either way is fine, do you prefer quasi? One side of the quasi is EF the other CFP so take your pick if you make it complementary. |
#3 |
I would like to build it as close to the original as possible.
Of course, because of the un-availability of the original set of transistors, I need to identify suitable alternatives. Ths is proving difficult as I am unable to locate the specs of those devices |
#4 | |
It would be nice to build it so that you could go up to +/-45 or 50V on the supplies, the 2N3773 is a very similar part and would allow this, it's actually a preferred part at On Semi. I'd go with a 2N3773 if you must have close to original. A more up to date TO3 part is the MJ15003 which has the best SOA. If you don't mind plastic the modern choice is MJW21195 - 16A, 250V, 200W should be fine, I'd double up on them to be safe into 2 ohm loads and accidental shorts. If you plan to go surplus and want to use any of the 15A, 115W parts make sure their at least 90V and I'd double up on these also. Again the HK drivers are odd, the RCA design used the 40409/40410, and I stated in another thread that the MJE253/243 (or MJE15034/35) plastic parts are a better substitute 4A/100V/40W, good beta, good Ft, this is a current part. Use a small heat sink with them. Bias transistor in the HK is 2N5232 and a dual diode is used for thermal sensing. The RCA design uses a three diode string, 2 are 1N3754 which mount to the output transistors with a metal holder, I'd add a 100 ohm pot in series for bias adjust. Predriver is a 40408, .7A, 90V, 1W, hFE 40-200@10mA, Ft 100 MHz. MJE243 is a good substitute, or 2N3440. The diff pair is a PNP dual transistor which provides excellent matching. The HK manual states that there is no substitute. The RCA design uses 40406 transistors and suggests selecting them. You can hand match the old standard 2N5087, which Leach used and tells you how to match at his page: http://users.ece.gatech.edu/~mleach/lowtim/part2.html Get ideas on parts sources, and transistors Leach uses: http://users.ece.gatech.edu/~mleach/lowtim/part3.html You many notice that this is nearly a copy but made complementary CFP: http://sound.westhost.com/project3a.htm And this might be helpful also, see Fig 33: http://www.dself.dsl.pipex.com/ampins/dipa/dipa.htm |
#5 |
Later Citation 12s used matched pairs of 2N5087 for the
input diff pair. My experience (both from genuine HK C12'a and from about 20 DIY clones of it) is that both the original canned diff pair and the 2N5087s tended to get noisy and then die, probably because of marginal voltage rating. I honestly can't figure out why one would want to replicate this design. There are any number of designs similar in topology but more refined in execution. For example, the various Doug Self "Blameless" designs take this simple topology to much more refined heights (in terms of "objective" measurements) and would likely "sound better" as well. The HK Citation 12 chassis and transformers do provide a very good platform for DIY amp designs. I currently have a modified Nelson Pass MOSFET-output version in one chassis.
bel |
#6 |
hi aged one,
Have a look in the Pass Labs forum. The Citation 12 gets talked about reasonably often.
Greg Erskine |
#7 | ||
#8 | |
I tried the OnSemi 2N3773 and it is on the edge of stability, it bursts into oscillation when driven into slewing with a square wave. Tried many other OnSemi models, MJ15003, MJW21195, MJ802 they're not as bad as the 2N3773 but also have very poor stability. They show very high beta when I use a test circuit, which is probably closer to the typical device that's seen in real life. I wonder if they've got the HF parameters right? I've built the Citation with substitutes (2N3790, 2N3714 outputs) for all the transistors, and know of one built with 2N3773s they both worked fine - never any smoke. Had one uneventful transistor failure that was probably just a normal failure. I think there's a problem with the simulation. |
#9 |
"it's 20 kHz distortion is lower than the Leach."
Yea but the Citations 12's TIM levels are off the charts! I wouldn't waste my time with this as a project. I converted piles over to the Pass version back when I was a bench tech. All the customers that had it done fully agreed it was miles ahead of the original version. Overall the Pass conversion is a much better choice and still keeps the parts count very low. Mark |
#10 | |
I think it's an excellent first project either way that one wants to build it. The poster asked for as close to original and that's what we're talking about. He could always convert it later. Did you measure the TIM? I've talked a lot about TIM in another thread but I think it's rare that source material has fast enough rise time to send an amp into slewing/TIM. I think the Citation had lower power into 4 ohms than 8 indicating an output current limitation, this is one thing I'd like to address, it was probably caused by beta droop. Pete B. |
| Substitute for Small signal transistors in crown 1400 csl | bobcat | Solid State | 2 | 2nd August 2009 11:51 AM |
| Citation 12 help | paco161 | Solid State | 173 | 24th April 2009 12:25 PM |
| Transistors Substitute | ali_moinuddin | Solid State | 11 | 27th October 2008 03:23 PM |
| Looking for substitute Transistors for MPSA56, MPSA06 | robin2d | Parts | 5 | 18th October 2004 07:44 PM |
| Page generated in 0.14950 seconds (85.54% PHP - 14.46% MySQL) with 11 queries |
