Old 20th February 2004, 07:27 PM   #1
KlausB is offline KlausB  Germany
KlausB's Avatar
Default single ended mosfet amp
Hi there,
I intend to build a single ended power amplifier, capable to deliver 10 watts into 4 Ohm and 8 Ohm speakers. The schematic below illustrates the circuitry planned:
The two input transistors are 2SJ162 p-channel mosfets, developed especially for audio purpose. At 100mA quiescent current their transconductance is around 0.35 S, hence with a 270 Ohm drain resistor the gain is around 90. The total gain of the input stage should be around 45 due to the identical source impedances of the two input transistors.
Core of the output stage is the 2SK1058, which is complementary to the 2SJ162. It is flanked by two powerful IRFP150 n-channel mosfets. The lower one is simply a current sink, the upper IRF150 cascodes the 2SK1058, keeping a constant voltage of 15V across the 2SK1058.
I am planning to inject about 10db feedback into the input stage via Ry which leaves a total gain of 14 of the amp.
The heat dissipation is enormous and the amp heavily violates the Kyoto protocol, but it should sound good. The most crucial component will be the output capacitor IMHO. Which brand can be recommended ?
Unfortunaty I do not have the means to do any computer simulation and so far my experience with power mosfets is very limited. Thus I would appreciate any comment or suggestion.
Cheers
KlausB
Old 20th February 2004, 09:45 PM   #2
pjacobi is offline pjacobi  Germany
Send a message via AIM to pjacobi Send a message via MSN to pjacobi Send a message via Yahoo to pjacobi
Default Re: single ended mosfet amp
Hi KlausB,
I hope the MOSFET experts will bite to give professional insight, in the meantime, I'll give some random remarks:
It seems you have access to a computer - why don't you have access to circuit simulation? You can use free LTSpice from http://www.linear.com/software/
Regarding Kyoto protocol: Didn't you recently had a major flooding in Dresden? And contrary to claims of the tinfoil head faction, class A amplifiers doesn't necessarily sound better the lower the efficency is. 10W out for burning 200W - can't get much lower.
But what's really strange here: why trying to make the output MOSFET more linear by cascoding and then nevertheless applying NFB. IMHO (and it's really humble) you can either go with cascoding and without NFB into the strange critters camp or without cascoding (and with much less dissipation) and with NFB into the fairly normal camp.
Peter Jacobi
YMMV
Old 21st February 2004, 02:34 AM   #3
Also as another note, the two input transistors (2sj162) in the differential pair are overkill (and a bit on the expensive side). These are output transistors for audio and would be put to better use as such. Smaller mosfets could be used for the input stage. You might have a look over at pass labs and check out the inputs on the Alephs as they use mosfets for the differential stage.
-Dozuki
Old 22nd February 2004, 07:07 PM   #4
KlausB's Avatar
OK,OK,OK, I accept the joke about my Class A design violating the Kyoto protocol was not that good and I certainly did not want to offend anybody concerned about our global environmental problems. Indeed the Dresden flooding in 2002 was a catastrophe and I will not forget the day and night when we struggled to remove library archives and laboratory equipment from the basements of our dental school while the firefighters (yes, they came from Hamburg !!) continued pumping to keep the water level below 1 meter.
But back to the topic.
Thanks for you comments and the link to Linear Technology. I read about SPICE in numerous forum posts, but I did not know its free downloadable software. So far I went through the educational files of SwCADIII - quite impressive. However, I searched intensively for spice model files simulating IRF9610, IRFP150, 2SJ162 and 2SK1058 MosFets here in the forum and on the web. I found some advice how to integrate new models into the SwCADIII library but not these files.
Any idea where to get those models ?
Are the 2 SJ162 an expensive overkill ? May be yes. But I want the circuit to be as linear as possible even without any feedback and according to the datasheets the 2Sj162 are more linear than the IRFP 9610. The question whether this is of sonic relevance will be subject to future experiments. I will start with the cheaper IRFs.
Cheers
KlausB
Old 22nd February 2004, 08:03 PM   #5
The one and only
Nelson Pass's Avatar
Originally posted by KlausB
:Are the 2 SJ162 an expensive overkill ? May be yes. But I want the circuit to be as linear as possible even without any feedback and according to the datasheets the 2Sj162 are more linear than the IRFP 9610. The question whether this is of sonic relevance will be subject to future experiments. I will start with the cheaper IRFs.
Are they more linear? I can't tell from the data sheets I've got
because the curves aren't good at the low currents involved.
I do know that the 2SJ162 has way lots more junction
capacitance, and about the same transconductance. It would
be interesting to actually compare the performance between
the two.
Old 22nd February 2004, 08:19 PM   #6
Hi KlausB,
[...]offend anybody concerned about our global environmental problems.[...]
I don't think your circuit will become so popular, that it can deliver a significant share to global warming.
Indeed the Dresden flooding in 2002 was a catastrophe...
I don't know Dresden but from the train window, but we visited Bad Schandau the year before and it was rather unbelievable, to see in the pictures, to which level the water raised.
In fact there are other free offerings (the simulator in itself was always open source), but most of them are demos limited to some device count.
So far I went through the educational files of SwCADIII - quite impressive. However, I searched intensively for spice model files [...]
Yup. Here starts the nasty stuff. The eternal hunt for models, and after having found these, the doubts how good they are. If you wan't to work more with SPICE, you most likely need a book about all these modeling, some looks to news://sci.electronics.cad and a membership of the LTSpice support group at http://groups.yahoo.com/group/LTspice/
[...] IRF9610, IRFP150, 2SJ162 and 2SK1058 MosFets here in the forum and on the web. I found some advice how to integrate new models into the SwCADIII library but not these files.
The IRF models are at the manufacturer's site. They are subcircuit based, so that usage in LTSpice needs some work, but this is handled in a tutorial at the Yahoogroup.
Googling for '2SJ162 spice' should have given you a hit:
http://www.diyaudio.com/forums/showt...6926#post26926
As I've already stated, accepting 5% efficency AND having non-local feedback is expensive overkill. Especially, if you consider to which issues the mony and effort could be diverted.
Don't kill the messenger, but I cannot resist claiming that a BJT used as follower (and cascaded by an IRF to eliminate Early effect) will be the most linear solution. Of course you should stay well below the so called rated ICmax but look for the fT maximum to find a suitable device.
I would use
http://www.sanken-ele.co.jp/en/prod/...f/2sd2561e.pdf
Yes, this is a monolithic Darlington, and those have no standing in high-end audio, but give it a try.
(And because it's not that cheap and maybe hard to get, just try some slow old big package Darlington for baseline - like BDV64, TIP142 or SGSD100)
Let us know the results!
Peter Jacobi
YMMV
Old 22nd February 2004, 08:30 PM   #7
Netlist is offline Netlist  Belgium
Netlist's Avatar
[B
[/B]
Here's the IRF9610 model:
http://www.diyaudio.com/forums/showt...6154#post36154
And here's the rest:
.MODEL IRFP150 NMOS (VTO=3.8916 KP=20U L=2U W=833.6M GAMMA=0 PHI=600M
+ LAMBDA=391.331U CBD=6.3026N IS=10F CGSO=1.13517N CGDO=1.13517N TOX=0 NSUB=0
+ TPG=1 UO=600 RG=69.5617 RDS=400K )
.MODEL 2SJ162 PMOS (VTO=842.193M KP=20U L=2U W=21.3317M GAMMA=0 PHI=600M
+ LAMBDA=20.7067M RD=837.199M CBD=2.96862N IS=10F CGSO=1.13517N CGDO=1.13517N
+ TOX=0 NSUB=0 TPG=1 UO=600 RG=50 RDS=1MEG )
.MODEL 2SK1058 NMOS (VTO=403.969M KP=20U L=2U W=29.7482M GAMMA=0 PHI=600M
+ LAMBDA=184.988F RD=60.8251M CBD=2.56138N IS=10F CGSO=1.13517N CGDO=1.13517N
BTW: I liked your joke
Edit: Oops...I'm slowing down these days...
/Hugo
Old 22nd February 2004, 09:06 PM   #8
KlausB's Avatar
Thanks a lot Netlist
KlausB
Old 22nd February 2004, 09:15 PM   #9
KlausB's Avatar
Peter,
thanks for the suggestions and the links. I will see, if I can get a SPICE model running and then simulate also the BJT option.
KlausB
Old 23rd February 2004, 08:56 PM   #10
Hi KlausB,
As you intend to have a design which is linear before non-local feedback, the two parts can be designed, simulated and even tested seperately.
The output stage is often referred as "Power Follower" and googling for this term (plus "MOSFET", maybe) will give you a fine selection of designs.
For curiosity I've put my suggestion into LTSpice, see here:
PDF: http://www.linearaudio.de/scratch/po...r-casc-hyb.pdf
LTSpice: http://www.linearaudio.de/scratch/po...r-casc-hyb.asc
In fact, compare this is this small signal follower
PDF: http://www.linearaudio.de/scratch/el...llower-mod.pdf
LTSpice: http://www.linearaudio.de/scratch/el...llower-mod.asc
which was discussed in the thread Simple discrete unity gain buffer
There is only a small difference in Iq: 1mA vs. 3.3A
As far as the simulation can tell you, this power follower is fine in all respects but efficeny. It's consuming about 200W (15W per Darlington and 85W per IRF), and delivers 33W into 6Ohm.
At 15V peak (18W), simulated THD is 0.06% (K3 is 0.016%).
To a varying degree the active devices' models look suspicious to me, but maybe the magic of cascoding will make the measured behaviour more like the simulated one.
Peter Jacobi
YMMV
Single-ended mosfet-tube follower KlausB Solid State 44 17th May 2009 06:28 PM
Tube-Mosfet Single-Ended Amplifier! Matthewong Solid State 15 2nd October 2008 05:13 AM
Single Ended, Single driver: In-room distortion measurements Gerrit Boers Full Range 4 27th November 2007 08:12 AM
Page generated in 0.15905 seconds (87.06% PHP - 12.94% MySQL) with 11 queries
