Rule of thumb for wattage?
Why bother calculating.
Fit the 8ohms speaker/s and listen.
8ohms speaker will not damage a 4ohms capable amplifier
And
the amplifier will perform better into the higher load impedance.
And
you may find that the 8ohms speaker is more sensitive/efficient and you get more sound output at the same source volume setting.
Tried it with multiple amps. I get distortion before I reach the volume desired. Also, the gain has to be set high which increases noise. The amplifier output is less into an 8 ohm load.
I could always use a bridged 4 channel on the fronts and a 2 channel un-bridged on the rears. But I'm limited on space.
