#101 | |
See a summary of some references on it, within my Duncan/Self power amp book review. Using the B-S circuit as a current mirror also isn't new. See Fig. 3 within reference 11, i.e., "In #11 the Thompson composite complementary pair is used in Figures 3 and 4 as a current mirror employing 2N3904/3906 discrete transistors." I don't mean to sound critical here, but you asked if I'd seen this circuit. Just pieces, as noted. Overall it looks like a fascinating circuit, but as it seems, validated thus far via SPICE. Is this correct? Walt Jung |
#102 |
Hi Walt,
You are right, all the pieces, in its own right, aren't new. The only thing that is probably new is the combination (and application) of these pieces, in particular with TMC. >validated thus far via SPICE That's correct. At the moment I'm busy with gathering components and PCB artwork. I hope it does work in real life as well. Thank for comments. Cheers, E.
Een volk dat voor tirannen zwicht, zal meer dan lijf en goed verliezen dan dooft het licht…(H.M. van Randwijk) Last edited by Edmond Stuart; 11th July 2012 at 08:10 PM. |
#103 |
Readers should carefully note the correction of the Baxandall-Shallow authors. I am attaching an updated PDF, which corrects post #87, which erroneously refers to them as "Baxandall-Swallow".
I regret any confusion this may have caused. Walt Jung |
#104 |
in this case this URLs also of interest:
The "Starved-Circuit" Amplifier Is Revived In A Transistor Version and Compound vs Darlington Last edited by tiefbassuebertr; 12th September 2012 at 07:10 AM. |
#105 |
Tief I fail to see what sziklai has to to with super pair.
The CCS amp is interesting, know the patent and the author ?? I ask because Ive seen that circuit published in public and wondering if its the same author. |
| FS: Tonegen/Tonigen Ribbon super tweeters PAIR | Antripodean | Swap Meet | 4 | 24th April 2012 12:53 PM |
| FS - Super Helix Gold SC - 8' pair | hafp | Swap Meet | 0 | 15th July 2009 08:56 PM |
| DIY Baxandall network | Craig405 | Solid State | 5 | 3rd September 2005 10:04 AM |
| Baxandall Eq | brianti | Analogue Source | 3 | 2nd November 2004 02:38 AM |
| 3-band Baxandall | BoGoMiPz | Solid State | 0 | 28th February 2002 11:49 AM |
| Page generated in 0.67485 seconds (100.00% PHP - 0% MySQL) with 10 queries |
